1stClass Studio 2013 for Delphi XE5 Full Source
1stClass provides the supreme collection of components for delivering applications that will impress. From its eye-catching image-shaped forms, to its powerful and polished tree view and outlook bar components, you will notice 1stClass' quality and attention to detail.
1stClass Studio 2009 allows developers to easily expand the global reach of their applications with built-in support for Unicode when using Delphi 2009 and C++ Builder 2009. Built-in support for Unicode means that applications will look and operate proplerly on all language versions of Windows and seamlessly support both Unicode and ANSI data.
Download : Как увидеть ссылки? | How to see hidden links?
Hi All Dumpz Freinds, I found these resources and want to share with you,
Enjoy :)
Premium Style Pack for RAD Studio XE5
This style pack works with Delphi/C++Builder/RAD Studio XE5. It includes styles for Windows, Mac, iOS, iOS 7 and Android.
Available free to registered users of Delphi XE5, C++Builder XE5, RAD Studio XE5 (except Starter editions), and Embarcadero All-Access XE
For instructions on how to use custom styles in your FireMonkey applications, please visit : Как увидеть ссылки? | How to see hidden links?
These tools are must have and could make your life easier, they are free from : Как увидеть ссылки? | How to see hidden links?
I send special thanks to the blogger Rodrigo for his valuable work
Delphi IDE Theme Editor
The Delphi IDE Theme Editor is a freeware tool which allow to change the Delphi (RAD Studio) and Lazarus IDE color settings from scratch or importing existing themes from another IDE like Visual Studio or Eclipse Themes, the current version supports Delphi 5, 6, 7, 2005, BDS/Turbo 2006 and RAD Studio 2007, 2009, 2010, XE, XE2, XE3, XE4, XE5.
Features
Supports Delphi 5 ,6 ,7, 2005, BDS/Turbo 2006 and RAD Studio 2007, 2009, 2010, XE, XE2, XE3, XE4, XE5.
Support the Lazarus IDE (v 0.9.30-1.0.1.3)
Import Visual Studio Themes 2003, 2008, 2010, 2012 (.vssettings)
Import Eclipse Themes (Eclipse Color Theme Plugin)
You can revert any changes made to the IDE pressing the button “Set default theme values for selected IDE”
Change Hue/Saturation of any Theme
400+ themes ready to use.
The Delphi 5 and Delphi 6 are supported emulating the original colors of the themes in a 16 color palette for more info read this post.
+560 Visual Studio themes included ready to import (check the Themes VS folder).
+1700 Eclipse themes included ready to import (check the Themes Eclipse folder).
Downloads:
Installer of the Delphi IDE Theme Editor : Как увидеть ссылки? | How to see hidden links?
Binaries of the Delphi IDE Theme Editor : Как увидеть ссылки? | How to see hidden links?
Themes Megapack 1 (+560 Visual Studio themes imported): Как увидеть ссылки? | How to see hidden links?
Themes MegaPack 2 (+1700 Eclipse IDE themes imported): Как увидеть ссылки? | How to see hidden links?
50+ Lazarus Color Schemes : Как увидеть ссылки? | How to see hidden links?
Lazarus Color Schemes Mega Pack 1 (+550 themes ready to use in your Lazarus IDE) : Как увидеть ссылки? | How to see hidden links?
Lazarus Color Schemes Mega Pack 2 (+1700 themes ready to use in your Lazarus IDE) : Как увидеть ссылки? | How to see hidden links?
Object Pascal WMI Class Generator
The Delphi WMI Class Generator is an application which creates full documented Object Pascal classes to access the WMI (Windows Management Instrumentation).
Features :
The code generated is compatible Delphi 7, 2005, BDS/Turbo 2006 and RAD Studio 2007, 2009, 2010, XE and the Free Pascal Compiler 2.2.4 (Win32)
Create full documented classes compatible with the help insight feature, available since Delphi 2005.
Create helper functions to retrieve the description of the returned values for the properties and functions.
Downloads:
Installer : Как увидеть ссылки? | How to see hidden links?
Binaries : Как увидеть ссылки? | How to see hidden links?
WMI Delphi Code Creator
The WMI Delphi Code Creator, allows you to generate Object Pascal, C++ and C# code to access the WMI (Windows Management Instrumentation) classes, events and methods.
for more infos please visit : Как увидеть ссылки? | How to see hidden links?
Downloads :
The Delphi Preview Handler
The Delphi Preview Handler, is a preview handler for windows vista and 7 which allow you read your object pascal, C++ and Assembly code with Syntax highlighting without open in an editor, this preview handler can render these file extensions .pp, .lpr, .lfm, .lpk, .inc, .pas, .dpr,.dfm, .dpk,.dproj, .bdsproj,.c, .cpp,. cc,.h, .hpp,.hh, .cxx, .hxx, . cu, .asm.
Downloads :
Installer (recommended) of the Delphi Preview Handler : Как увидеть ссылки? | How to see hidden links?
Binaries of the Delphi Preview Handler : Как увидеть ссылки? | How to see hidden links?
VCL Styles
The VCL Styles Utils is a collection of classes and style hooks, which extend and add new features to the VCL Styles (introduced in Delphi XE2).
for more infos, full source code and documentation please visit : Как увидеть ссылки? | How to see hidden links?
SMBIOS
SMBIOS stands for System Management BIOS , this standard is tightly related and developed by the DMTF (Desktop Management Task Force).
The SMBIOS contains a description of the system’s hardware components, the information stored in the SMBIOS typically includes system manufacturer, model name, serial numbers, BIOS version, asset tag, processors, ports, device memory installed and so on.
IP*Works S-MIME v9.0.4972 port to XE5
New & Updated Components
Below is a short list of some of the new and exciting individual component updates available in the IP*Works! V8.
NEW: JSON - Easily integrate with web services that produce JSON output.
NEW: CalDAV - Access calendar/scheduling information on remote servers.
ATOM - A new ATOM client component with support for publishing (APP).
REST - New component implements a standard REST client, facilitating access to REST style Web Services such as those from Amazon and eBay.
DNS - Support for new query types, reverse DNS lookups, etc.
FTP/TFTP - Upload/Download Files to/from memory without writing to disk.
HTTP/WebUpload - Upload/Download Files to/from memory without writing to disk.
IPPort/IPDaemon - Facilitated file and data transfer through easy to use methods like "SendFile", etc.
LDAP - Support for search result references. Easily move and copy DNs.
MIME - Parse mime headers without decoding entire MIME entities
Ping - Send custom ping packets and change datagram sizes.
RSS - RSS 2.0 extensions and OPML support, and other improvements.
SMPP - SMPP receive capabilities enable the component to poll SMPP servers for messages.
XMPP - Support for Jabber extensions, additional contact parameters, and SASL authentication.
XMLp - Expanded XPath navigation and support for easy retrieval of XML subtrees.
...and much more!
Добавлено через 4 минуты
EMS Advanced Data Export VCL v4.9.0.1 for D5-XE5 Full Source
Advanced Data Export VCL is a component suite for Borland Delphi and C++ Builder that allows you to save your data in the most popular data formats for the future viewing, modification, printing or web publication. You can export data into MS Access, MS Excel, MS Word (RTF), Open XML Format, Open Document Format (ODF), HTML, XML, PDF, TXT, DBF, CSV and more! There will be no need to waste your time on tiresome data conversion - Advanced Data Export will do the task quickly and will give the result in the desired format.
EMS Advanced Excel Report v1.9.2.1 for D5-XE5 Full Source
Advanced Excel Report for Delphi is a powerful band-oriented generator of template-based reports in MS Excel. Easy-to-use component property editors allow you to quickly create powerful reports in MS Excel. Now you can create reports, which can be edited, saved to file and viewed almost on any computer.
Добавлено через 7 минут
ShellBrowser Components v9.0.0.686 for Delphi 7 and RAD Studio XE-XE5
Enhance Your Delphi Application with Drop-in Shell Functionality
•Includes 18 visual and non-visual components
•Create Explorer-like applications within minutes with JamShellTree, the JamShellList and the JamShellCombo
•Easy drop-in: Just drop the UI components right on your own forms or dialogs
•Use checkboxes with JamShellTree, JamShellList, JamFileList and JamDriveList
Icons and thumbnails are queried in background threads. This optimizes the reactivity and does not slow down the speed of the user interface.
Look-and-Feel of the Windows Explorer
•Windows Shell context menu (can be extended with a Delphi popmenu)
•OLE drag-and-drop with the Windows Explorer and similar applications
•Different view styles: The JamShellList and the JamFileList support small icons, large icons, extra large icons, details mode and thumbnails
•Overlay icons supported
•Installed Shell extensions, which are supported by the Windows Explorer, are also supported by the ShellBrowser Delphi Edition
•TJamSystemShellView instances the right pane of the real Windows Explorer
•Background context menu in the JamShelllist is supported
How-to Guides
•Comprehensive documentation of the included controls
•Several sample projects for basic and advanced features of ShellBrowser Delphi Edition included
Transparent Costs
•The ShellBrowser Delphi Edition is royalty free and involves no runtime fees
100% Delphi Code•The controls are based on the Delphi VCL and are written in 100% Object Pascal code
•No additional DLLs or ActiveX controls are necessary
TMS Workflow Studio v1.9.0.0 Full Source
Workflow Studio is a Delphi/C++Builder VCL framework for Business Process Management (BPM). With Workflow Studio you can easily add workflow and BPM capabilities to your application,by allowing you or your end-user to create workflow definitions and running them.
v1.9.0.0
New : TAttachmentViewMode allow displaying attachments and task info in a single pane instead of different tabs
New : RAD Studio XE5 support
Improved : Better performance for saving/loading workflow definitions, instances and tasks when using ADO
Fixed : Workfklow blocks not displayed when language different than English was used
Fixed : Empty "Basic" category removed from toolbar
download : Как увидеть ссылки? | How to see hidden links?
SQL Direct v6.4.2 Delphi/C++Builder XE4-XE5 + key
IBM DB2 Universal Database
Informix Server
Interbase/Firebird Server
Microsoft SQL Server
MySQL Server
Oracle Database Server
PostgreSQL Server
SQLite Database
Sybase Adaptive Server Enterprise and Adaptive Server Anywhere
Unify (Centura, Gupta) SQLBase Server
ODBC datasources
OLEDB datasources
TMS Async v1.5.2.0
TMS Async is a communications package containing components which provide access to the serial ports under Windows. The event-driven architecture provides the highest possible performance and allows all the tools to run in the background.
A proven concept for over 6 years.
Advanced class object structure.
Advanced but easy to use design interface.
Optimized even t-driven architecture.
Provides the highest possible performance.
Supports all important transfer protocols.
Components to build advanced comport servers.
Easy to use with any type of serial hardware.
Links directly to your EXE, no runtime.
Built-in support for XModem, YModem & ZModem protocols
Codeless terminal component with extendable emulation interface
Component for codeless visualisation of status
