Devart UniDAC 5.2.5 (Source only)
5.2.5 25 December 2013
Oracle data provider
-An ability to establish OCI and Direct connections in the same application is supported
-New Oracle 12c connection modes are added (SYSBACKUP, SYSDG, SYSKM)
-Bug with connecting in the Direct mode under Windows 2000 and lower is fixed
-Bug with Password which length is exactly 16 characters for Oracle 10 in the Direct mode is fixed
-Bug with DB object names containing the '$' and '#' characters is fixed
-Memory Leak in the NonBlocking mode is fixed
SQLServer data provider
-Bug with incorrect committing of data by the Loader component on errors is fixed
MySQL data provider
-Bug with returning an incorrect value in the RowsAffected property is fixed
InterBase data provider
-Now RowsAffected returns a correct value without the need to prepare a statement explicitly
-Bug with string truncation when using the Loader component is fixed
-Bug when working with parameters of the ftTimeStamp type is fixed
PostgreSQL data provider
-Bug with handling international characters when using protocol version 2 is fixed
-Bug with backup of ENUM types using the Dump component is fixed
-Bug with Memory leak is fixed
SQLite data provider
-Direct mode for x64 platform is supported
-Now the Direct mode is based on the SQLite engine version 3.8.2
-Bug with executing multi-SQL statements is fixed
-iOS in C++Builder XE5 is supported
-RAD Studio XE5 Update 2 is now required
-Now .obj and .o files are supplied for C++Builder
-Compatibility of migrating floating-point fields from other components is improved
-Bug with data loss when updating records in the CachedUpdates mode is fixed
-Bug with RefreshRecord in the CachedUpdates mode is fixed
-Bug with Master-Detail when a connection and a query are placed in different units is fixed
-Bug with data display in Detail Dataset when master field is Null is fixed
-Bug with incorrect parameter sizes when re-opening a query is fixed
-Bug with mapping to BCD fields when using TClientDataSet is fixed
-Bug with mapping single types to float types is fixed
-Bug with mapping to BCD and FmtBCD types is fixed
-Bug with filtering boolean fields is fixed
-Bug with freeing complex fields after refreshing before editing is fixed
-Bug with Locate by fields where Data Type Mapping is applied is fixed
-Bug with RefreshQuick when IndexFieldNames is set is fixed
-Bug with the TUniLoader.AutoCommit property is fixed
