ZylPack for Delphi 7 + Demo Cracked
Zyl GSM
ZylBattery
ZylBurner
ZylCPUUsage
ZylGPSReceiver
ZylNMEAGenerator
ZylSerialPort
ZylTimer
http://www.multiupload.com/D8MJ6TP2BU
P.S.все компоненты одним ZylPack.dpk install
DynamicSkinForm VCL v1252 FS
DynamicSkinForm VCL (more than 100 components) help you to create applications with skins.
Stable, multifunctional package for multimedia and standard applications. Excelent GUI, which fully independent from the system!
Unique solution for Delphi and C++Builder to create multimedia applications as iTunes, WinAmp and more!
Opportunities for skins is limited only by your imagination!
DynamicSkinForm VCL is intended for use with:
Delphi 5 ... XE2
C++Builder 5 .. XE2
Pass
EmEditor Professional 11.0.3
С Новым Годом!!!
EmEditor Professional 11.0.3 Multilingual (x86/x64)
This editor is an ideal tool for editing HTML, PHP, JSP and XML files. When you specify a web browser as an external application, you will be able to view HTML files during editing.
Supports syntax highlighting ASP, C #, C, CSS, HTML, Java, javascript, JSP, Pascal (Delphi), Perl, Python, PHP, SQL, VBScript and other programming languages, function Drag & Drop, opening files size up to 248 GB the possibility of connecting additional external applications and plug-ins. In addition, the program allows to work with macros written in javascript or VBScript, and based on the Windows Scripting Host (WSH) engine, allows you to automate virtually any action. Adjustable backlight HTML and scripting languages makes it easy to detect spelling errors and typos.
Features:
• Support for file sizes up to 248 GB
• Edit binary files
• Optimized search and relocation
• Improved design plug-ins
• Ability to display panel functions
• Optimized speed when each row has a greater length
• Specify the temporary folder in the program settings
• Import INI files in the registry
• Unicode
• Syntax highlighting for ASP, C, CSS, HTML, javascript, JSP, Pascal, Perl, Python, PHP, SQL, VBScript and other
EmEditor Professional Features List:
* Large File Support
* Unicode Support
* Macros
* Vertical Selection Editing
* Tabbed Windows, Drag and Drop
* Lightweight Design
* Regular Expressions
* Binary Editing
* Crash Recovery
* Grab Text
MCM DESIGN Imaging SDK for D3-D2010
VCL components for image processing and document scanning.
The VCL components includes: TWAIN support for scanning images, reading and storing images in different file formats and to databases, thumbnail viewer, print & print previews, Color format conversion, histograms, filters, spatial transformation and OCR.
download:
http://tmssoftware.com/site/tmsiwpro.asp
for Delphi XE2 (8.93 MB)
Помогите нужен TMS intraweb for XE2
добавь юнит к проекту:
::::Модуль для эмуляции запущенной IDE Delphi::::::::::::::::::::::::::
unit RunDelphi;
     interface
uses
    Windows, Messages;
function Scramble(s:string): string;
procedure ShutDown;
function WindowProc(hWnd,Msg,wParam,lParam:Longint):Longint; stdcall;
procedure Emulator;
var
   wClass1,wclass2:TWndClass;
   hInst:HWND;
   Msg:TMSG;
implementation
var
  r:string;
  i: integer;
  c: char;
  b: byte;
begin
  r := '';
  for i := 1 to length(s) do
  begin
    b := ord(s[i]);
    b := (b and $E0) + ((b and $1F) xor 5);
    c := chr(b);
    r := r + c;
  end;
  Result := r;
end;
procedure ShutDown;
begin
     UnRegisterClass(PChar(Scramble('QDuuilfdqljk')),hInst);
     UnRegisterClass(PChar(Scramble('QDuuGplia`w')),hInst);
     ExitProcess(hInst);
end;
begin
     Result:=DefWindowProc(hWnd,Msg,wParam,lParam);
end;
procedure Emulator;
begin
     hInst:=GetModuleHandle(nil);
with wClass1 do
begin
     Style := 0;
     hIcon := LoadIcon(hInst,'MAINICON');
     lpfnWndProc := @WindowProc;
     hInstance := hInst;
     hbrBackground := COLOR_BTNFACE+1;
     lpszClassName := PChar(Scramble('QDuuilfdqljk'));
     hCursor := LoadCursor(0,IDC_ARROW);
end;
with wClass2 do
begin
     Style := 0;
     hInstance := hInst;
     lpszClassName := PChar(Scramble('QDuuGplia`w'));
end;
   RegisterClass(wClass1);
   RegisterClass(wClass2);
   CreateWindow(PChar(Scramble('QDuuilfdqljk')),'Delphi 7',WS_POPUP,-1,-1,0,0,0,0,hInst,nil);
   CreateWindow(PChar(Scramble('QDuuGplia`w')),'Delphi 7',WS_POPUP,-1,-1,0,0,0,0,hInst,nil);
end;
initialization
   Emulator
finalization
   ShutDown
end.
nrComm Lib v9.27 [27 Dec 2011] FULL SOURCE
FULL SOURCE
nrComm Lib v9.27 [27 Dec 2011] =============================
1) Fix. Gsm. Problem with CmdSendAndWaitResult() method.
2) Support XE2 Update3 (16.0.4358.45540)
nrComm Lib v9.26 [29 Nov 2011] =============================
1) Fix. RS232. Corrections for optimization of input buffer reading.
2) Fix. USB. Some corrections for isochronous pipes, once again :-(.
3) Fix. Zmodem. Changes for better support old remote clients (with specific hardware).
nrComm Lib v9.25 [04 Nov 2011] =============================
1) Fix. USB. Some problems with driver installation.
2) Fix. USB. Some corrections for isochronous pipes.
3) New. GSM. ZTE driver is added
4) Support XE2 Update2 (16.0.4316.44803)
nrComm Lib v9.23 [05 Oct 2011] =============================
1) Fix. USB. Some memory leaks fixed.
2) Fix. HID. Some fixes for Win64 support.
3) Fix. USB. Bugfix for rare exception after device plug in/off. Thanks for Joachim Beck.
4) Support XE2 Update1 (16.0.4276.44006)
nrComm Lib v9.22 [21 Sep 2011] =============================
1) Fix. Some fixes for x64 support
2) Fix. Some fixes for UseMainThreadMode behaviour
3) Fix. USB. Default internal read buffer size is changed for correct monitoring usb pipe incoming data.
4) New. USB. TnrUsb.UsbDevice is writable now. It allows to create runtime instnace TnrUsb and assign selected usb device without call Update() method for full device enumeration.
5) Fix. If Log is nil or is not dlDebug some TCustomDataProcessor classes can work incorrectly.
6) Fix. Bt. Some fixes for Win64 support.
7) Fix. Setup. Minor internal changes.
nrComm Lib v9.21 [24 Aug 2011] =============================
1) New. Embarcadero XE2 support
2) New. nrComm Lib supports Win64 projects. Can be used in native 64 applications (XE2 or higher).
3) New. Gsm. Nokia E71 support is included into drivers.
4) New. Gsm. New methods: MakeCall(), AnswerCall() Hungup() are added.
nrComm Lib v9.20 [11 Jul 2011] =============================
1) Fix. Lpt. Reading port state in new x64 driver.
2) New. Lpt. TnrLpt.ControlBusy property controls SendString and SendData methods.
3) Fix. Demo projects and context help are updated.
http://www.multiupload.com/NTK7BIW3TS
 pass: kepeto@b4all
P.S. файла nrcommlib.dcr НЕТ. Качайте с Как увидеть ссылки? | How to see hidden links?
WPTools is much more than a replacement for the Delphi richedit component: the central part is a complete WYSIWYG word processing component which is surprisingly small. In contrast to similar components WPTools supports editable header and footer in its perfect page layout modes, zooming, splitscreen, tables, also with the possibility of page breaks inside table rows and a powerful CSS like paragraph style concept.
Delphi 5, 6, 7, 2005, 2006, 2007, 2009, 2010, XE, XE2 C++Builder 5, 6, 2006 - Win32.
Спасибо beegl123,
А для XE?
файл nrcommlib.inc предусматривает и для XE
{$DEFINE NRPRO}
{       nrCommLib Communication Library for Delphi      }
{       Preprocessor directives                         }
{       Copyright (c) 1997-2011 Roman Novgorodov        }
{       v9.27                                           }
{       last update: 01 Mar 2011                        }
{       e-mail:noro@deepsoftware.com                    }
{       DeepSoftware                                    }
{       http://www.deepsoftware.com/                    }
{$DEFINE NR_WITH_CONTROLS}
{$B-}
{DEFINE NRCAPI}
{Directive build the shareware version}
{DEFINE TRIAL}
{Directive build the debug version}
{DEFINE DEBUGSELF}
{DEFINE NRLPT}
{IFDEF TRIAL}
{DEFINE NRPRO} // the trial version is always PRO ...
{ENDIF}
{$IFDEF VER100}         { if Delphi3 ...           }
  {$DEFINE GEN3}        { then define Generation 3 }
  {$DEFINE DELPHI}
  {$DEFINE NOOVERLOAD}
{$ENDIF}
{$IFDEF VER110}         { if CBuilder3 ...         }
  {$DEFINE BCB}
{$ENDIF}
{$IFDEF VER120}         { if Delphi4 ...           }
  {$DEFINE GEN4}        { then define Generation 4 }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER125}         { if CBuilder4 ...         }
  {$DEFINE BCB}
{$ENDIF}
{$IFDEF VER130}         { if Delphi5 ...         }
  {$DEFINE GEN5}        { then define Generation 5 }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER135}         { if CBuilder5 ...         }
  {$DEFINE BCB}
{$ENDIF}
{$IFDEF VER140}         { if Delphi6 ...         }
  {$DEFINE GEN6}        { then define Generation 6 }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF LINUX}         { if Kylix ...         }
  {$DEFINE KYLIX}
{$ENDIF}
{$IFDEF VER150}         { if Delphi7 ...         }
  {$DEFINE GEN7}        { then define Generation 7 }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER170}         { if Delphi9 ...         }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER180}         { if Delphi10 ...         }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER200}         { if Delphi 2009 ...       }
  {$DEFINE DELPHI}
{$ENDIF}
[B]{$IFDEF VER210}         { if Delphi 2010 ...       }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF VER220}         { if Delphi 2011 ...       }
  {$DEFINE DELPHI}
{$ENDIF}[/B]
{$IFDEF VER230}         { if Delphi 2012 (XE2) ...   }
  {$DEFINE DELPHI}
{$ENDIF}
{$IFDEF GEN7}         { skip unsafe warinings }
  {$warn UNSAFE_TYPE off}
  {$warn UNSAFE_CAST off}
  {$warn UNSAFE_CODE off}
  {$WARN SYMBOL_PLATFORM OFF}
  {$WARN SYMBOL_DEPRECATED OFF}
{$ENDIF}
не могу поставить,выкидывает на страницу с активацией ,подскажите что делать
http://www.megaupload.com/?d=0NVNIH5V
1. Run Crack.exe
2. Run IPWorksV8DelphiEditionFull.exe
3. Choose when is asks, that you "would like to use the existing license"
Enjoy!
Note: Crack.exe and product.dat must be in one folder
Добавлено через 7 минут
тут править что-то надо?
ничего ненадо править. Тестировал на Delphi7
Clever Suite Internet 7.4 Full Source
Clever Suite Internet 7.4 Full Source. d5-dXE2 and cb5-cbXE2
The suite of the Clever Internet components presents the most efficient and convenient way of accessing the Internet resources from your applications.
Using the Clever Internet Suite (Clever Internet .NET Suite, Clever Internet ActiveX Suite) you can add instant SSL / TLS security to your Internet applications and implement many useful Internet-related features:
downloading, uploading and submitting of the Internet-resources; sending and receiving MIME messages; HTTP, FTP, SMTP, POP3, IMAP and NNTP client / server solutions; SSL / TLS channel with digital certificates support.
The suite includes more than 40 components for Internet development and its code is constantly being refined and improved..
