thnx for trichview 13.6 path.
but problem was still. my program is a text rich for edit and import&export.
when delete a char with del key, trial message show.
Accuracer MU Pro 4.97 Full Source
Accuracer Database System is a Windows / Linux cross-platform BDE alternative embedded Delphi database with SQL support for software developers working in the Embarcadero RAD Studio, Borland (CodeGear) Delphi / C++Builder and Borland Kylix .
Accuracer represents the next generation of our Delphi databases products line which started more than 10 years ago with such highly famous and respected product as EasyTable. Accuracer Database System products line includes several independent DBMS products for working with the databases in Accuracer format: - Accuracer VCL - general package for software development in Delphi / C++Builder;
- Accuracer CLX - general package for Kylix;
- Accuracer Database Server - server application that is the part of Accuracer VCL (CS Std and CS Pro editions);
- Accuracer Utilities - package includes utilities with full source code;
- Accuracer ODBC Driver - ODBC version for Windows;
- Accuracer Bold DB Adapter - support for Borland Bold for Delphi , a usefull tool for data import/export;
- Accuracer Data Provider for Fast Query Builder - for visual query building;
- Accuracer Database Connection for Easy Query - for visual query building;
- Accuracer Data Provider for Active Query Builder - for visual query building using Active Query Builder.
Accuracer VCL/CLX includes a new original BDE alternative database engine which supports the almost all TTable, TQuery, TDatabase, TSession, TBatchMove functions and provides some special ones to give you high functionality and ease of use.
Accuracer is currently available for the Borland Delphi, C++Builder and Kylix development environments in Single-User (SU), Multi-User (MU) and Client/Server (CS) versions.
Key Features:
Client/server database engine with server component and custom messages
Easy-to-use multi-user (file-server) database engine
Multi-thread access
Storing all tables inside the single database file
Embedded database: no BDE, no DLLs
SQL'92 DML & DDL enhanced support with advanced statements
Correlated subqueries support in SELECT, UPDATE and DELETE SQL statements
SQL stored procedures and functions support
Case-insensitive search
Referential Integrity support (SQL'99 compliance)
100% Unicode support - SQL, filters, database objects names
Easy-to-use changes detection and write failures detection
Fully compatible with standard DB-aware controls
IProvider Support (ClientDataset)
Small footprint and low memory usage
In-Memory tables support for the fastest data access
Varchar and BLOB field types with optional data compression
Strong database encryption with wide variety of algorithms and modes
Transactions support with READ COMMITTED isolation level
BatchMove component
Reverse engineering (tables to SQL script export)
Backup and Restore support
Triggers - database and server events
Full Views support
Capability of database embedding inside the executable file
ODBC Driver available
Windows / Linux cross-platform database engine
No royalties
Native Delphi database, full source code available
Ideal as BDE replacement - does not require any .dll and includes data transfer utility.
Fast Report 4.12.1 for Delphi 4-XE2 and CB4-6 FS (32bit/64bit)
то же, что в посте #368, но удалены некоторые скомпилированные файлы, которые можно откомпилировать самому файлом recompile.exe. Поэтому размер уменьшен с 25 до 13 мб. Пароль не нужен.
Как там с Watermarkom/...
Absolute Database v6.20 for Delphi XE2 + Demo
Описание: Мощная система построения баз данных для Delphi. Альтернатива Borland Database Engine (BDE). Absolute Database - компактный, быстродействующий и удобный в работе механизм баз данных. С этой программой вы не будете нуждаться в специальных инсталляциях и конфигурациях, компилирование происходит сразу в EXE.
Основные возможности:
- поддержка SQL'92 (DDL & DML)
- нет DLL (engine базы данных компилируется непосредственно в exe-файл)
- база данных состоит из одного файла
- 100% совместимость со стандартными DB-aware элементами управления
- криптостойкое шифрование
- BLOB сжатие
- режимы Single-user и mutli-user (file-server)
- доступен полный исходный код.
Скриншоты :
Установка :
Для полной установки, замените файл vclAbsDbd16.bpl в папках :
- ComponentAce\AbsoluteDatabase\Lib\Delphi XE2 and C++ Builder XE2\
- System32
- SysWOW64
QuickReport Maintenance Release 2012-01-19 Delphi & CB 2009, 2010, XE, XE2 Full Source
19th January 2012
Maintenance release of Unicode Versions
New builds dated 19/01/2012 are available for
-Delphi & C++Builder 2009
-Delphi & C++Builder 2010
-Delphi & C++Builder XE
-Delphi XE2
Fixes include
1. QRAbsDataset is fixed
2. PDF exporter - character widths for different codepages fixed.
NativeExcel Suite v3.x (для Delphi 4-XE2) + Demo - это высокопроизводительное решение для разработчиков Delphi, что позволяет написания новых электронных таблиц Excel и чтение существующих.
ПРЕИМУЩЕСТВА:
- Высокая производительность; - Удобная модель объекта;
- Поддержка всех вариантов Excel форматирования;
- Microsoft Office не требуется;
- Чисто Delphi исходный код;
- Полный пакет документации с многочисленными примерами;
ОСОБЕННОСТИ:
- Открыть существующий файл Excel;
- Доступ к любой ячейке значения (число, строка, дата, булево, формула);
- Расчет двигателя для выполнения вычислений на клетки;
- Атрибуты ячейки (выравнивание, комментарии, ориентация, границы, фон атрибуты, и так далее);
- Атрибуты шрифта (название шрифта, размер шрифта, цвет, украшения, и так далее);
- Изображения поддержки (BMP, JPG, PNG, EMF, WMF);
- Объединенные ячейки;
- Unicode символы поддержки;
- Копировать / Переместить / Удалить / Вставить диапазон ячеек;
- Группа строк и столбцов;
- Гиперссылки поддержки;
- Лист атрибуты (имя, защита);
- Печать атрибутов (размер страницы, ориентацию, поля, нарушает колонтитул, заголовок страницы, и так далее);
- Чтение защищенные паролем (с шифрованием) Excel файлов;
- Экспорт рабочих книг и листов в HTML, RTF, CSV, TSV файлов;
- TDataset2Excel компонента. Заполняет таблицу из потомков TDataset;
- TDBGrid2Excel компонента. Заполняет таблицу из потомков TDBGrid;
NativeExcel Suite v3.x (для Delphi XE2) + Demo - это высокопроизводительное решение для разработчиков Delphi, что позволяет написания новых электронных таблиц Excel и чтение существующих.
Mirrors:
