N'importe quoi
TMS Component Pack for Delphi & C++Builder includes feature-packed grids, Office 2007 ribbon, Office 2003 style toolbar, planning/scheduling components, advanced edits, toolbars, internet auto application update, Office 2003/2007 style tabs, pager, panel, Outlook navigational controls and much much more... Create modern-looking & feature-rich Windows applications faster with over 300 components in one money and time saving bundle
Grid components
HTML components
Edit controls
Planner components
Outlook / inspector bar components
Web connectivity components
Syntax highlighting memo component
System components
Graphic components
Menu components
Smooth components
Miscellaneous components
Full component list
List of samples
N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi N'importe quoi
EurekaLog Delphi XE3
For those ppl who need EurekaLog under Delphi XE3:
You must have installed prior and working (for example under Delphi XE2) EurekaLog Enterprise version. I have 6.1.05.rc3.
1) Install 6.1.05 under XE3 - doesn't work, but creates registry keys
2) Copy c:\program files\eurekalab\eurekalog 6\ and subfolders from working version (Delphi XE2) into your Delphi XE3 OS (I use VMWarePlayer and virtual machines, so it's simple)
3) Add paths to Delphi IDE (Options->Library->Library path). After standard installation this is
c:\program files\eurekalab\eurekalog 6\delphi16.
If you made step 1) this path should be added
4) Open project c:\program files\eurekalab\eurekalog 6\delphi16\ExceptionExpert16.dproj
5) Open unit c:\program files\eurekalab\eurekalog 6\delphi16\ECore.pas
6) Change 2 instances "DecimalSeparator" into "FormatSettings.DecimalSeparator"
  Result := QuickStringReplace(FloatToStr(ADateTime), FormatSettings.DecimalSeparator, '.');
  S := QuickStringReplace(S, '.', FormatSettings.DecimalSeparator);
7) Compile, install, enjoy :)
PaxCompiler.v3.1.DateCode.20121217.Full.Source
EMS.Advanced.Query.Builder.v3.9.1.1.Full.Source
EMS.Advanced.Excel.Report.v1.9.1.1.Full.Source
Кому нужно. Только что вышел.
Simple Graph Component 2.81 D4-XE3
TSimpleGraph is a visual component, which provides a simple user interface for drawing graphs. The control and its graph objects are fully customizable in the way that let you create almost any kind of graphs.
RAD XE3 Update 1 C++Builder x32 - x64 it works
Crack
Rad XE3 witch update 1 torrent
Получилось так:
1) Заменить borlndmm.dll в папке bin (лучше просто временно переименовать)
2) Запускаем и потом выходим из RAD Studio XE3
3) Применил патч предложенный medreis (антивирус вырублен!!! иначе никак особенно если у Вас KIS 2013)
4) Вернул обратно оригинальный borlndmm.dll в папку bin
Все!
Serial: MAFA-A3D7PD-FJBBAE-FACN
