Apollo Embedded 7.2
Embedded database engine for developing applications that manage CA-Clipper and FoxPro 2.6 DBF database files locally or on a shared LAN environment. Includes ADO.NET Data Provider for .NET, native VCL components for Delphi & C++Builder, OLEDB Data Provider for ADO, COM objects, and components for classic ASP web pages.
Note: Apollo 7.2 supports developing 32-bit Windows 8 and Windows 7 applications. Windows RT is not supported.
CRUD support for DBF/NTX/DBT, DBF/CDX/FPT, DBF/NSX/SMT files
RAD Studio XE3, XE2, XE, 2010, 2009, 2007
Delphi XE3, XE2, XE, 2010, 2009, 2007, 2006, 2005, 7, 6, 5
C++Builder XE3, XE2, XE, 2010, 2009, 2007, 2006, 6, 5
Visual Studio 2012, 2010, 2008, 2005, 2003
.NET 4.5, 4.0, 3.5, 3, 2, 1.1
OLEDB Provider and COM objects for VB, VC++, ASP
Скачать / Download
Features:
Apollo Server is built using Apollo 7.2
Enables Apollo 7 applications to connect and manage DBF/Xbase database files remotely (client/server)
Only 5 lines of code to make your Apollo 7 applications work with the Apollo Server
SQL-92 support
High-speed, secure TCP/IP access to Clipper, FoxPro 2.6 and Apollo DBF/Xbase databases
700KB Server footprint
10 to 30 times faster performance over embedded multi-user applications
Server Manager utility manages users and database aliases
Improves data integrity in multi-user environments
Reduces network traffic in multi-user environments
Minimal data is sent between client application and server
Eliminates Windows file sharing and file locking performance issues on shared networks
Does not require expensive hardware to run, works great on desktop-class machines
Royalty free unlimited distribution
Скачать / Download
