Компоненты к Delphi (каталог ссылок)
TUsers Security Component 2.0.5
TUsers Security Component - User Management made easy for Delphi and C++ Builder developers
If you are looking for User Authentication and User Rights Management for Delphi and C++ Builder, you are in the right place.
Our Security Components will help you protect your application in a very easy and elegant way.
Just drop our security components in your forms and datamodules, configure a few properties and methods and your application is already protected.
With the TUsers Security Component, you can protect menus, buttons, actions, dbgrids, datasets, fields and virtually any VCL component, even 3rd-party componentes, like DevExpress and JVCL.
PE Explorer v1.99
PE Explorer makes it easy to view, analyze and edit win32 executable files. It offers a thorough look at PE file structure and all of the resources in the file, and tells you just about every little detail you could possibly want to know about a PE file (EXE, DLL, ActiveX, and other executable formats). PE Explorer comes with a Visual Resource Editor, PE Header Viewer, UPX Unpacker, Exported and Imported API Function Viewer and Syntax Lookup, Dependency Scanner, and a powerful win32 Disassembler.
Once inside, file structure can be analyzed and optimized, problems diagnosed, changes made and resources repaired. Leveraging the power of PE Explorer Disassembler, you can rapidly analyze the procedures and libraries a malware executable uses without ever activating the executable itself. Version 1.99 includes a Digital Signature Viewer and the ability to mark pre-Vista applications with a requested execution level, providing the way to deploy the same build of the application on both Windows Vista and Windows XP.
Добавлено позднее:
InterBase Data Access Components v2.10.0.10
InterBase Data Access Components (IBDAC) library offers a set of nonvisual components for Borland Delphi, C++ Builder and Kylix. They provide access to InterBase, Firebird and Yaffil database servers. You can use IBDAC as an alternative to standard way of accessing databases using Borland Database Engine (BDE) or dbExpress.
Delphi, BCB & Kylix:
Oracle Data Access Components v6.10.1.10
Oracle Data Access Components is the powerful tool to develop client/server applications on Borland Delphi, C++ Builder and Kylix with Oracle. ODAC provides flexible and easy automatic updating server data, advanced locking and refresh rows, advanced support of Oracle8 objects, arrays, nested tables, BLOB and CLOB data types and has a lot of another useful features.
SQL Server Data Access Components v4.10.0.10
SQL Server Data Access Components is the powerful tool to develop client/server applications on Borland Delphi and C++ Builder with Microsoft SQL Server. SDAC provides flexible and easy automatic updating server data, refresh rows, getting metadata and has a lot of another useful features.
Delphi & BCB:
MySQL Data Access Components v5.10.0.10
MySQL Data Access Components is the powerful tool to develop client/server applications on Borland Delphi, C++ Builder and Kylix with MySQL server. MyDAC provides flexible and easy automatic updating server data, refresh rows, getting metadata and has a lot of another useful features.
ExpressBars Suite V6.27
Доброго времени суток всем добрым людям!
Если есть возможность, поделитесь, плиз: ExpressBars Suite V6.27
Буду очень благодарен!
Люди, помогите, нужен Fast Report 4 с поддержкой D2007!!! Спасибо
Текущая версия
- исправлена ошибка с размером страницы в наследованных отчетах
Версия 4.2
+ добавлена поддержка CodeGear Delphi 2007
DevExpress Suite Full V6.27
Если есть возможность, поделитесь, плиз: DevExpress Suite Full V6.27
:) Буду очень благодарен!
