Документации по GCRI для Wildfire5 нет
Пробовал под F000?
Но нашел такую инфу
Before setting up GCRI, the application component "readnewermodels.dll" will need to be obtained and placed in the proper location.
It is available on the Free Downloads page on PTC.com. General information can be found on the following webpage:
The "readnewermodels.dll" available on this page will be updated periodically as significant changes are made to GCRI, but not with every build of Pro/ENGINEER.
Beginning in datecode M100 of Pro/ENGINEER Wildfire 4.0, and F000 of Wildfire 5.0, the "readnewermodels.dll" is copied into the Pro/ENGINEER loadpoint (<Pro/ENGINEER load point>\<platform>\readnewermodels.dll). Each datecode will include the matching version of "readnewermodels.dll".
It is supported on various platforms in various releases of Pro/ENGINEER. See the following webpage for a release and platform matrix:
Unicode character encoding has been introduced in Pro/ENGINEER Wildfire 4.0. Conversion of Unicode to EUC encoding used in earlier Pro/ENGINEER releases is not supported by GCRI. This issue is visible when converting files with Unicode language characters, used in parameters, model notes, and model names to EUC encoded releases.
1) Obtain the version of the "readnewermodels.dll" application component appropriate for the later release being used (Wildfire 3.0, 4.0, or 5.0) and place this application component in the <machine_type>/obj directory below the Wildfire 2.0, 3.0, or 4.0 loadpoint as shown below. The application component to allow Wildfire 5.0 components to be retrieved in an earlier release is valid for Wildfire 4.0 and 3.0. The application component to allow Wildfire 4.0 components to be retrieved in an earlier release is valid for Wildfire 3.0 and 2.0. The application component to allow Wildfire 3.0 components to be retrieved in an earlier release is valid for Wildfire 2.0. Note that the platform of the DLL and the version of Wildfire in which the DLL is being placed must match.
For example: <loadpoint>/i486_nt/obj/readnewermodels.dll
2) Add the following config options to the config.pro of the earlier release of Pro/ENGINEER PRIOR to launching Pro/ENGINEER.
topobus_enable yes
atb_show_log off
atb_auto_check_on_update off
atb_auto_check_on_retrieve on
3) Add the following config option to the config.pro of the later release of Pro/ENGINEER PRIOR to launching Pro/ENGINEER.
cri_grafting_enable yes
4) Launch the earlier release of Pro/ENGINEER and check to see that the #File > #Associative Topology Bus is available.
5) Validate the installation by checking for the following:
When a model from a later release of Pro/ENGINEER is retrieved in an earlier release, the message "You are opening a Pro/ENGINEER Part created in Pro/E Wildfire <release>. Would you like to proceed opening it as a GRANITE model?".
After retrieving a later-release model in an earlier release, select any feature, RMB > #Info > #Feature. Under the "Comments" section, the message "FEATURE IS READ-ONLY" is displayed.
PS попробуй использовать библиотеку для Wildfire4.0
В WF5 смотри папку Х:\PTC\proeWildfire5\x86e_win64\gcri\
