Црео 2 М050 ис онлы 700 мб,ис тхис юст упдате?
oops sorry
PTC Creo 2.0 M050 installtion issue
invalid format or file
Please fix or guide how to install.
Till PTC Creo 2.0 M040 it was fine but now it gets stucks with this error.
I'm having the same problem as Israr Ullah
How can i fix this error in Creo 2.0 M050 installtion issue
Israr Ullah,
sarpedaniel88,
It means that you made mistakes at editing template of license file before pointing to existing license file
You have changed HOSTID=00-00-00-00-00-00 for wrong HOSTID of your computer
or
You have changed not all strings with HOSTID=00-00-00-00-00-00
or
You have add some wrong symbols in license file while editing
I'm still trying to install Creo 2.0 M050 but it's the same installtion issue
:-((HELP
What is your Windows?
What is your computer HOSTID?
Here is tool to determine actual HOSTID (if you don't know how to use ipconfig /all command)
h-ttp://letitbit.net/download/77225.771565beb01be081e0b970154559/Host_ID.rar.html
using this tool you will get HOSTID in format xxxxxxxxxxxx, you need to edit it to format xx-xx-xx-xx-xx-xx
I have windows 7 ultimate
My host id is 00-1D-72-CB-D2-86
i'm trying to edit my lic file but
no luck
When i tipe "ipconfig/all"in cmd i keep geting this message
"ip config" is not reconized as an internal or externalcomand operable program or batch file
Добавлено через 42 секунды
doesn't work:-(
could be a virus
no luck
doesn't work:-(
could be a virus
"bull sh..t!
Files in HOST_ID.rar are standard flexlm files (lmutil.exe).. It can be found in any original FlexLM package.. They are free from viruses!!
Tune your paranoic antivirus!!
As far as for ipconfig /all command
Not ipconfig/all but ipconfig /all
Can you see space bar before /all ??
So I need your REAL hostid
P.S. Check if you have environment variable LM_LICENSE_FILE on you computer and if positive for what license file it points to..
