PlotLab_VCL_6.0.0.123 - D/C-XE5
PlotLab is a set of very fast data plotting / charting / graphing components. Add sophisticated interactive graphs, charts, plots, and waterfalls to your VB.NET, C#, Visual C++, Delphi and C++ Builder applications with minimal effort.
Добавлено через 5 минут
InstrumentLab_VCL_6.0.0.123 - D/C-XE5
InstrumentLab is a set of visual instruments and controls based on GDI+. For Delphi / C++ Builder, InstrumentLab is a set of native VCL components
IntelligenceLab_VCL_6.0.0.123 - D/C-XE5
IntelligenceLab is an Artificial Intelligence library that can be used for data grouping, SPAM filters, computer vision, speech recognition, or any other classification task.
The library contains classifiers, training components, and a general purpose neuron component.
Typical applications:
SPAM filters.
OCR applications.
Computer Vision.
Speech recognition.
Data classification.
Decision making.
IntelligenceLab is implemented using very fast MMX optimized libraries.
TMS Component Pack 7.1.3.0 D6-XE5
TMS Component Pack 7.1.3.0 D5-XE5 Full Source
Добавлено через 3 минуты
SynEdit D5-XE5 Full Source
Unicode SynEdit
This is the Unicode version of SynEdit, a syntax highlighting editor that had
originally been designed for ANSI character sets.
For the available information check out the "Unicode SynEdit" Web-site at:
The ANSI version of SynEdit is located at:
The SynEdit project has also a page at SourceForge
where you may find additional information.
SignalLab_VCL_6.0.0.123 - D/C-XE5
SignalLab is a set of components for very fast digital signal processing (DSP). The library allows very fast complex signal manipulations and visualization with zero lines of program code.
Applications include: real time data acquisition, process control, signal analysis, digital signal analysis, audio analysis, video analysis, data visualization, visual instrumentation and more.
A simple signal generation tutorial (.NET or VCL) and a more complex signal analysis tutorial (.NET or VCL) are available in the tutorials section.
WDApp (WebKit & Delphi FrameWork)
WDApp (HTML5 application framework)
WDApp = Webkit & Delphi
This Project is base on:
DCef3(Как увидеть ссылки? | How to see hidden links?)
Cef wapper(Как увидеть ссылки? | How to see hidden links?)
you can use HTML + javscript to developer native applcation.
it is simple to add navtive method, and use cef single or multi process mode.
Support: D7, XE2, XE3, XE5
Devart UniDAC 5.2.5 - source only 5.2.5 25-Dec-13
5.2.5 25-Dec-13
-iOS in C++Builder XE5 is supported
-RAD Studio XE5 Update 2 is now required
-Now .obj and .o files are supplied for C++Builder
-Compatibility of migrating floating-point fields from other components is improved
-Bug with data loss when updating records in the CachedUpdates mode is fixed
-Bug with RefreshRecord in the CachedUpdates mode is fixed
-Bug with Master-Detail when a connection and a query are placed in different units is fixed
-Bug with data display in Detail Dataset when master field is Null is fixed
-Bug with incorrect parameter sizes when re-opening a query is fixed
-Bug with mapping to BCD fields when using TClientDataSet is fixed
-Bug with mapping single types to float types is fixed
-Bug with mapping to BCD and FmtBCD types is fixed
-Bug with filtering boolean fields is fixed
-Bug with freeing complex fields after refreshing before editing is fixed
-Bug with Locate by fields where Data Type Mapping is applied is fixed
-Bug with RefreshQuick when IndexFieldNames is set is fixed
-Bug with the TUniLoader.AutoCommit property is fixed
Oracle data provider
-An ability to establish OCI and Direct connections in the same application is supported
-New Oracle 12c connection modes are added (SYSBACKUP, SYSDG, SYSKM)
-Bug with connecting in the Direct mode under Windows 2000 and lower is fixed
-Bug with Password which length is exactly 16 characters for Oracle 10 in the Direct mode is fixed
-Bug with DB object names containing the '$' and '#' characters is fixed
-Memory Leak in the NonBlocking mode is fixed
SQLServer data provider
-Bug with incorrect committing of data by the Loader component on errors is fixed
MySQL data provider
-Bug with returning an incorrect value in the RowsAffected property is fixed
InterBase data provider
-Now RowsAffected returns a correct value without the need to prepare a statement explicitly
-Bug with string truncation when using the Loader component is fixed
-Bug when working with parameters of the ftTimeStamp type is fixed
PostgreSQL data provider
-Bug with handling international characters when using protocol version 2 is fixed
-Bug with backup of ENUM types using the Dump component is fixed
-Bug with Memory leak is fixed
SQLite data provider
-Direct mode for x64 platform is supported
-Now the Direct mode is based on the SQLite engine version 3.8.2
-Bug with executing multi-SQL statements is fixed
pass: board4allcz.eu
Добавлено через 2 минуты
FastReports 4.14.1 D7-XE5(Changed by someoneself)
TMS Plugin Framework v6.0.5 D5 to XE2 FullSource
I need "TMS Plugin Framework v6.0.4 For XE2 , FS"
Добавлено через 16 минут
I need the TMS component for plugins please
Wireless communication Library 6.12.8.0
Приветствую, господа!
Вышла новой версии Wireless Communication Library 6.12.8.0.
Что нового
  • Fixed BlueSoleil pairing bug when app freezes;
  • Changes in HFP connection controller;
  • Code optimization;
  • Small bugs fixed;
  • OnOBEXGetComplete event updated to allow to call other OBEX operation from this even handler;
  • Toshiba connection issue fixed;
  • BlueSileil BT 2.1 Simple Pairing support has been added.
Остальное, как обычно:
1. Только для некоммерческого использования. Подразумевается использование без извлечения прибыли: фривара, для себя любимого и т. п.
2. Коммерческая лицензия доступна с большими скидками. Обращайтесь на Как увидеть ссылки? | How to see hidden links?, будем рады.
3. Как получить. Стучите нам на Как увидеть ссылки? | How to see hidden links?
Если от нас долго (более 3-х часов) нет ответа, то либо у нас ночь и я сплю либо ваше или наше письмо было уничтожено спам-фильтром. По сему можно кинуть в нас еще раз на Как увидеть ссылки? | How to see hidden links?
Ну вот как-то так.
P.S. Кто уже к нам обращался и не получил обновления, стукните еще раз.
HTML Viewer Component D6-XE4
HtmlViewer 11.4
New Features:
- Help file HelpView.hlp as been replaced with THtmlViewer.chm. All sources are included.
- Supports HTML tags: dfn, ins, del, abbr, acronym.
- Supports HTML table attribute: frame, rules.
- Supports CSS property: white-space.
- New demo FrameBrowserUsingId10?.exe using Indy 10.
- New print preview dialog
- shows any number of print pages horizontally and vertically
- zooms preview
- zooms page content (e.g. to fit content into page)
- included in the FrameViewer projects
- Significantly reduced memory consumption of large tables with lots of and/or huge spans.
More than 31 issues fixed.
For details:
download and start "FrameDem.exe" and click "What's new"
or see "./Demos/Compiled Framedemo/whatsnew.htm".
The HtmlViewer component set consists
of the THtmlViewer, TFrameViewer, and TFrameBrowser components.
All three are HTML document display components:
THtmlViewer
The basic component.
THtmlViewer displays single (non-frame) documents.
It also forms the basis for the other two components.
TFrameViewer
Displays both frame and single HTML documents.
TFrameViewer is oriented more for local file system use.
TFrameBrowser
Also displays frame and single HTML documents.
TFrameBrower is oriented for use with local file systems
and toward Internet style protocols and URL usage.
Additional code and/or components are generally required
to get data from other sources than the local file system.
These components support most of the HTML 3.2 specifications
with many additional popular HTML 4 and 5 enhancements.
Many Cascading Style Sheet properties are also supported.
