TscExcelExport Version 4.23 (October 2013) - freeware for non-commercial use - Delphi VCL
This TscExcelExport component is an advanced, powerful but easy to use component which enables you to export all records of a dataset from Borland/Codegear/Embarcadero Delphi to Microsoft Excel. Many features are provided to change the layout, use conditional formatting, to add totals, to create groups, to set a filter, ... The component works in Delphi 5, 6, 7, 2006, 2007, 2009, 2010, XE, XE2, XE3, XE4 and XE5 (32 and 64 bit) and it supports Excel 97, 2000, XP, 2003, 2007, 2010 and 2013.
ICS все версии качайте с сайта разработчика, они бесплатные.
На данный момент это лучшие компоненты для работы с сетью:
полностью неблокирующий режим работы на событиях, многопоточный сервер.
Кому не нужна поддержка экзотики типа компиляции x64 кода, IPv6, FireMonkey, качайте ICS-V7 Gold.
Эта ветвь изначальная и поддерживается параллельно, а восьмая сделана специально для внесения этой поддержки.
ICS components are best net support for RAD Studio. They are free to use and always available on official developer's site
ICS-V8 is a new brench with support of x64, IPv6, and FireMonkey.
If you dont need this, use ICS-V7.
Its more lightweight and seems more reliable, developers continue its support as well.
Gnostice PDFtoolkit VCL ProPlus 3.4.8 D5-XE Crk
Gnostice PDFtoolkit is a versatile PDF component suite for Delphi/C++Builder developers.
PDFtoolkit VCL components come with hundreds of functions and properties that put immense power in the hands of the developer.
PDFtoolkit hides the complexity of the PDF format and allows developers to easily create applications that can edit, enhance, secure, merge, split, display, and print PDF documents and forms.
PDFtoolkit does not require PDF software such as Adobe PDF library, Adobe Acrobat Professional or Ghostscript.
NEW releas 2.6.0 of D.P.F Android Native Components
Features:
classes.dex merged with Delphi XE5 with Update 2
Fixed build.bat compile error
Added HTTPDownload Demo
Added TDPFJHTTP (with Authentication)
Wrapped Android.OS.Environment
Added TDPFJRelativeLayout
Added TDPFJLinearLayout
Added TDPFJListView
Added TDPFJWebView WebSettings property(JavaScriptEnabled, UserAgentString, ...)
Fixed Controls align(s) on any device!
Fixed TDPFJTabHost PageIndex Order
Removed TDPFJView, use : TDPFJRelativeLayout, ...
Delphi Tips Manager : Collection of 6800 delphi tips !!!
it's an efficient tool that allows you to find your tips easily and quickly. 6800 delphi tips are included, and you can add your own tips freely. Not only for Delphi, but also a good tips & tricks management tool for other programming languages., It's lite, It's green, It's freeeee!
Download : Как увидеть ссылки? | How to see hidden links?
D.P.F Android Native Components v2.06 XE5 + Demo
Classes.dex merged with Delphi XE5 with Update 2
Added TDPFJListView
Added TDPFJWebView WebSettings property(javascriptEnabled, UserAgentString, ...)
download: Как увидеть ссылки? | How to see hidden links?
TeeChart Pro for Delphi and C++, VCL and FireMonkey BETA – 14-Jan-2014
Supported IDEs:
For Delphi 5,6,7, 2006, 2007, 2009, 2010, XE, XE2, XE3, XE4, XE5
C++ Builder 2006, 2007, 2009, 2010, XE, XE2, XE3, XE4, XE5
RAD Studio 2007, 2009, 2010, XE, XE2, XE3, XE4, XE5
Lazarus LCL 1.2 (not yet perfect)
Important Note:
Please backup your projects before opening and saving forms (dfm / fmx) using this beta build. Otherwise you'll might not be able to open them using previous TeeChart versions,
as this new version updates published properties.
