XLSSpreadSheet v2.00.02 (XLS engine v5.20.14) for Delphi 7 & RAD Studio XE-XE5 (x32)
XLSSpreadSheet 2 is a native Delphi component for editing and viewing Microsoft Excel files
  • With XLSSpreadSheet, you can work with Excel files just as they in Excel itself. The component don't need any other software or libraries to be installed.
  • XLSSpreadSheet works togheter with XLSReadWriteII, wich also is included. XLSSpreadSheet is easy to use. If you are familiar with XLSReadWriteII, you allready have the knowledge that's needed, as all control of the Excel data is trough the XLSReadWriteII object of XLSSpreadSheet.
  • The latest version of XLSReadWriteII is included when you purchase XLSSpreadSheet.
  • XLSSpreadSheet also comes with components for printing and print preview.
  • Full source code is included.
  • No runtime fees for the component.
2.00.02
- New instructions for printing PDF files. See the InstallPDF.txt file.
! Vertical lines on PDFConfused.
! Margings where not set on PDF
ImageEn 4.0.2 Full Source Only x86 with Demos
Support: D5-XE2, CB5-XE2
ImageEn is the most powerful native image library available for Delphi and C++ Builder, and is also available for .NET. The library includes a complete suite of components to handle all aspects of image and editing, analysis and display. Join thousands of other developers who rely on ImageEn to add professional multimedia functionality to their software.
DKLang Localization Package 5.0
DKLang Localization Package is a set of classes intended to simplify the
localization of applications written in Delphi.
At Version 5.0 DKLang Localization Package has been rewritten to work on
all current (XE5) platforms: VCL (win32 & win64) & FireMonkey (win32,
win64, OSX, Android, & iOS).
Добавлено через 16 минут
ImageEn 4.1.4 Full Source with Demos
Support D5-XE only x86, XE2 & XE3 x86-x64.
Magenta RAS Component 5.72 without Source
TMAGRAS - DELPHI RAS COMPONENT - RELEASE 5.72
Compatible with Delphi 7, 2007, 2009, 2010, XE, XE2, XE3 and XE4.
With XE2 and later, Win64 is supported as a target, as well as Win32.
Note that release 5.72 only supports ANSI RAS APIs with Delphi 2009 and
later.
Compatible with Windows XP, 2003 Server, Vista, 2008 Server, 7, 8
and 2012, both 32-bit and 64-bit editions.
later.
Это все бесплатное!!!!
Castalia 2014.1.2 Suite XE5
Castalia 2014.1.2 is available now, with the following bugfixes:
Fixed: Smart keys not working in Delphi 2005, 2006, and 2007
Fixed: Synchronize prototypes incorrectly handles some variables with ‘const,’ ‘var,’ etc…
Fixed: Smart Home key doesn’t work on blank lines
Fixed: Synchronize prototypes can leave extra text in the file if formatting conventions weren’t followed closely enough
Fixed: Delphi 7 crash on close
Fixed: Error CCI 2738 when editing a Delphi unit with no project open
Fixed: Castalia doesn’t support [Unsafe] attributes class fields
Fixed: Synchronize prototypes doesn’t handle empty parameter lists (empty parenthesis) correctly
Castalia users with a current subscription can download Castalia 2014.1.2 from the download site right now.
FireDAC 8.0.5 Full Source
Support: D5-XE4
Our goal with FireDAC is to provide you with the best high-speed native data access layer available for Delphi, C++ Builder, and RAD Studio. These Release Notes contain a few guidelines that you should follow in order to properly install and get started with FireDAC. More information about the product is available at FireDAC Home Page.
1. Delphi, C++ Builder Installation
The installer automatically installs FireDAC in the Delphi XE4 and C++ Builder XE4 IDEs. For older versions of the IDEs, you can run the installer with the /SHOWIDE command line parameter.
2. SynEdit Integration
FireDAC uses SynEdit for advanced query editing, including sytax highlighting in the design-time editors. To enable SynEdit integratin you should download and install SynEdit into Delphi IDE.
3. Sample Projects
The sample projects are included in the \Samples folder of your FireDAC install. All projects are using FireDAC Demo Database, which must be installed on your database server.
4. Help Files
The help files in PDF, Html Help and Help2 formats are included in the \Help folder of your FireDAC install. Or the Online Help may be used.
5. Where To Go From Here
To get started using FireDAC, please read the Getting Started articles. And look for the demos in the Samples\Getting Started folder.
Apollo Server 7.3
Optional database server allows Apollo 7 Embedded applications to connect to CA-Clipper, FoxPro 2.6 and Apollo data files over TCP/IP. Ideal for building client/server applications. (Requires Apollo 7 Embedded)
-Provides efficient data access over TCP/IP
-Alias Manager
-Relay Server included for firewall integration
Info: Как увидеть ссылки? | How to see hidden links?
Добавлено через 11 минут
Apollo Embedded 7.3
Embedded database engine for developing applications that manage CA-Clipper and FoxPro 2.6 DBF database files locally or on a shared LAN environment. Includes ADO.NET Data Provider for .NET, native VCL components for Delphi & C++Builder, OLEDB Data Provider for ADO, COM objects, and components for classic ASP web pages.
Note: Apollo 7.3 supports developing 32-bit Windows 8 and Windows 7 applications. Windows RT is not supported.
-CRUD support for DBF/NTX/DBT, DBF/CDX/FPT, DBF/NSX/SMT files
-RAD Studio XE5, XE4, XE3, XE2, XE, 2010, 2009, 2007
-Delphi XE5, XE4, XE3, XE2, XE, 2010, 2009, 2007, 2006, 2005, 7, 6, 5
-C++Builder XE5, XE4, XE3, XE2, XE, 2010, 2009, 2007, 2006, 6, 5
-Visual Studio 2012, 2010, 2008, 2005, 2003
-.NET 4.5, 4.0, 3.5, 3, 2, 1.1
-OLEDB Provider and COM objects for VB, VC++, ASP
FastReport Enterprise v4.15.6 for D4-XE5 installer(setup key include)
Current version
Build : 4.15.6
Date : Jan 22, 2014
version 4.15
- fixed memory leaks in font packing subsystem
+ Added Embarcadero RAD Studio XE5 support
+ Added Internal components for FireDac database engine
+ fixed bug with images in PDF export for OSX viewers
+ Added ability to set font charset to default in Style Editor
- fixed duplex problem when printing several copies of the report
- fixed problem with PNG images
- fixed problem with TfrxPictureView transparent
Download : Как увидеть ссылки? | How to see hidden links?
OmniThreadLibrary 3.03a D2007-XE5 x86-x64
OmniThreadLibrary is simple to use threading library for Delphi.
You can use high-level primitives like parallel for, futures and pipelines to introduce parallelism into your application.
OmniThreadLibrary supports Delphi 2007, 2009, 2010, XE, XE2, XE3, XE4, and XE5 on the Win32 and Win64 platforms.
1. OmniThreadLibrary is FREE and Open Source -- Как увидеть ссылки? | How to see hidden links?
2. Latest version is 3.03b -- Как увидеть ссылки? | How to see hidden links?
Changes since 3.03a:
- New features:
- Added SetPriority function to the IOmniTaskConfig.
- Added indexed writers ([number] and [name]) to both TOmniValue and
TOmniValueContainer.
- Bug fixes:
- Thread priority is set correctly (to 'normal') if it is not
explicitly specified.
- Corrected swapped content of 'Schedule Observed'/'Schedule
Unobserved' methods in the 11_ThreadPool test (tnx to [semele]).
- Locked<T>.Free can be called if Locked<T> owns its Value.
NexusDB 3.1100 Dev.Edition Full Source D7-DXE3
Include Bonus, etc.
Support also: CB11-CB17
The NexusDB database engine for Delphi is our award winning flagship product. NexusDB is a royalty-free, SQL:2003 core compliant, Client/Server and Embedded database system, with features that rival other heavily licensed products. NexusDB introduces unique new features for Delphi developers while further improving on its core strengths stability, performance and flexibility.
