у меня у одного проблемы с этими девками? после установки .. при запуске делфи начинает ругаться на отсутствие модулей, хотя в папке они лежат, после перезапуска компа косяков меньше.. но так же остались, что делать?
RadStudia 2007 если что
1. uninstall current and previous version devexpress
2. clear your system from all devexpress files.
3. install
Very Important: REBOOT after installation, or the path to the libraries will not be found (The installer creates an environment variable with the path to the libraries, and it is only activated by giving a BOOT or log off).
In RAD Studio XE2 manually add the path to the libraries (in Tools \ Options \ Delphi Options \ Library \ Library Path).
PS: TeeChart 9 Installation does not work, should be compiled manually after installation.
eDocEngine for XE2 plz
Добавлено через 2 минуты
virtual Treeview for XE2 plzzz
Billenium Effects for Delphi XE2 plz
SmartEffects is an easy-to-use VCL that enables you to create amazing splash screens, forms, controls and image transition effects.
Over 50 families of animation and transition effects.
WYSIWYG editing of animation effects.
its better if you request for components in Как увидеть ссылки? | How to see hidden links?
eDocEngine try Как увидеть ссылки? | How to see hidden links?, and
Virtual Treeview you can search through Как увидеть ссылки? | How to see hidden links?
GLScene Nov 17, 2011
GLScene is an OpenGL based 3D library for Delphi. It provides visual components and objects allowing description and rendering of 3D scenes in an easy, no-hassle, yet powerful manner.
GLScene is not just an OpenGL wrapper or utility library, it has grown to become a set of founding classes for a generic 3D engine with Rapid Application Development in mind. GLScene allows you to quickly design and render 3D scenes without having to learn the intricacies of OpenGL, if you know how to design a TForm, you'll easily master the basic operations of GLScene. The library comes with a large collections of demos showcasing the ease of use, and demonstrating RAD wasn't done at the expense of CPU/GPU horsepower.
Password Edocengine Plzz
EurekaLog – даст вашим приложениям (GUI, Console, Web, и т.д.) возможность улавливать любое отклонение от нормы, а также находить замкнутые циклы и мертвые точки программы. EurekaLog создает детализированный отчет по действию, вызвавшему отклонение от системы (номер строки, класса, метода), отображает его на экране и выборочно отсылает почтой или по сети (с помощью HTTP-S/FTP протоколов), таким образом ускоряя процесс определения ошибок и их решения.
EurekaLog прост в использовании, т.к. полностью интегрируется в IDE – нужно всего лишь перезапустить приложение. EurekaLog не влияет на работу приложений (программа включается, только когда обнаружено отклонение от нормы в системе) и увеличивает размер двоичных файлов только на 0.5% - 4% (для хранения сжатой декодированной информации по решенным задачам). EurekaLog использует только двоичные файлы, не трогая .MAP файлов.
EurekaLog совместим с Delphi XE2
Отдельное спасибо Kilya
Комплект TMS Unicode Component Pack предназначен для разработки приложений с поддержкой Unicode. Включает более 60 элементов управления для Delphi & C++Builder, заменяющих все стандартные VCL-элементы управления. В ОС Windows 95/98/ME Unicode не поддерживается.
Ключевые особенности:
- Объектный инспектор Delphi/C++Builder с поддержкой Unicode;
- Подсказки с поддержкой Unicode;
- Хорошо работает почти со всеми IME (редакторами метода ввода);
- Поддержка локальных переменных Unicode;
- Корректное отображение свойств WideString на формах.
