TMS Advanced Charts 3.0.6.1 for D6-XE2 Full Source
TAdvChartView & TDBAdvChartView : fast multi-pane & DB-aware chart component
-Single or multi pane chart view component
-Vertical or horizontal oriented charts
-Wide range of chart types: Line, Bar, Area, Pie, Spider, Donut, Band, Stacked Bars, Stacked Area, --OHLC, CandleStick, Histogram, Bubble, Error, Digital Line ...
-Different bar shapes such as rectangle, cylinder and pyramid
-X-axis with index of date/time unit indication
-Linear or logarithmic Y-scale
-Y-axis with auto ranging, minor & major value indication along Y-axis, multiple Y-axis values for different series supported
-Support for annotations & legend
-Panes with scrolling, scaling, splitter, drag & drop, synchronized scrolling with mouse or keyboard
-Highly configurable crosshairs with value indication at series, Y-axis, tracker & crosshair support along multiple panes
-Navigator bar to help for scrolling series along X-axis
-Floating tracker window to see values at crosshairs
-Configurable grid & bands
-Configurable margins for chart & chart background image
-Printing support, export to bitmap support
-Support for persisting chart settings to file
-Interface component to synchronise automatically with TAdvStringGrid / TDBAdvGrid
-DB-aware panes and series
FlexCompress v5.10 for XE2 + patch + *.bpl
FlexCompress is a compression delphi component designed for creating archives with strong encryption and better compression rate than WinZip and RAR. Native VCL, no DLLs, no OCXs, provides compression for files, buffers, streams and strings, supports in-memory archives, compresses large files > 4 Gb with low memory consumption and lots of other useful features.
Now with full Unicode support!
DevArt dbExpress driver for SQLite Version 2.1.2
dbExpress is a database-independent layer that defines common interface to provide fast access to SQLite. For this database engine, dbExpress provides a driver as an independent library. As data-access layer is thin and simple, dbExpress provides high performance database connectivity and is easy to deploy. You can use our driver in the same way as the one supplied by Embarcadero.
dbExpress driver for SQLite provides direct high performance access to SQLite databases. The driver requires SQLite library "sqlite3.dll".
Key features
The following are the main features of our dbExpress driver for SQLite:
*Direct access to data
*High performance
*Encryption support
*SQLite concurrent access
*SQLite Shared-Cache mode
*Support for all SQLite data types
*Unicode and national charsets support
*Full support for dbExpress version 4
*Ability of monitoring query execution with dbMonitor
*Source code available
*Includes annual Subscription with Priority Support
*Licensed royalty-free per developer
IDE Compatibility
The following development environments are supported by dbExpress driver for SQLite:
-Embarcadero RAD Studio XE2 (Requires Update 2)
-Embarcadero Delphi XE2 for Win32
-Embarcadero Delphi XE2 for Win64
-Embarcadero Delphi XE2 for OSX32
-Embarcadero C++Builder XE2 for Win32
-Embarcadero C++Builder XE2 for OSX32
-Embarcadero RAD Studio 2010
-Embarcadero Delphi 2010
-Embarcadero C++Builder 2010
-CodeGear RAD Studio 2009
-CodeGear Delphi 2009
-CodeGear C++Builder 2009
-CodeGear RAD Studio 2007
-CodeGear Delphi 2007 for Win32
-CodeGear Delphi 2007 for .NET
-CodeGear C++Builder 2007
-Borland Developer Studio 2006
-Borland Delphi 2006 for Win32
-Borland Delphi 2006 for .NET
-Borland C++Builder 2006
-Turbo Delphi Professional
-Turbo Delphi for .NET Professional
-Turbo C++ Professional
-Borland Delphi 2005
-Borland Delphi 7
-Borland Delphi 6 (Requires Update Pack 2 – Delphi 6 Build 6.240)
-Borland C++Builder 6 (Requires Update Pack 4 – C++Builder 6 Build 10.166)
Only Architect, Enterprise, and Professional editions are supported.
Supported Target Platforms
*Windows, 32-bit and 64-bit
*Mac OS X
*Note that support for 64-bit Windows was introduced in Delphi XE2, and is not available in C++Builder and older versions of Delphi. Support for Mac OS X was introduced in Delphi XE2 and C++Builder XE2, and is not available in older versions of Delphi and C++Builder.
