Rave Reports for Delphi XE2 Installation Package
This is the installation package Rave Reports for Delphi XE2. Usefull if you install Delphi Lite 5.x that don't have it.
Установочный пакет Rave Reports для Delphi XE2
FoxBurnerSDK 5 for Delphi
Pixbyte’s FoxBurner SDK is a complex but easy to use CD/DVD/BD Recording Framework. The FoxBurner SDK hides the complexity of CD/DVD/BD burning, authoring and manipulating and lets you concentrate focus on your own application.
FoxBurner SDK Premium Suite
This is the core package of the FoxBurner SDK. There are three packages available:
Windows: Download the binary ready to use samples and the complete Framework for C++, VB6 and .net. Includes help files, libraries, assemblies and samples.
Mac: Download a binary installer to see how the SDK works on MAC. Development Version available on request.
Linux: Download the Debian binary installer. Development version available on request.
eDocEngine VCL v3.0.4.269
eDocEngine VCL is a comprehensive e-document creation component suite for Delphi™ and C++Builder®. eDocEngine can create documents in clipboard, PDF, RTF, HTML, XHTML, EXCEL, TEXT, CSV, Quattro Pro, LOTUS 1-2-3, DIF, SYLK, TIFF, PNG, SVG (XML-based vector graphics), JPEG, GIF, BMP, EMF and WMF formats. eDocEngine ships with ready-to-use Report-Export interfaces that tightly integrate with popular Delphi reporting tools such as ReportBuilder, FastReport, Rave, QuickReport, and Ace Reporter. Using eDocEngine Report-Export interfaces, you can directly export reports to PDF and other formats without having to write any code.
Dbisam 4.31 + Help (for Delphi 2007 Only) No Source
DBISAM is the standard for replacing the BDE in Delphi or C++Builder applications. It has has been deployed to thousands of locations around the world, and can be branded so that no one even knows that DBISAM is being used. It is licensed per-developer, and includes royalty-free distribution. License management isn't required at all, and the money that you used to pay to the database engine vendor is now your profit to keep.
You don't need to use a feature-crippled "free" product in order to avoid licensing fees anymore. With Elevate Software, you are backed by a company that has over a decade of experience in highly-distributed and pre-packaged database application software. A year of phone, Skype, and email support is included with every purchase, and we can provide on-site consulting services at a very reasonable rate to give you the special attention that you deserve.
DI HtmlParser 6.0.0 CRACKED
Парсер и анализатор HTML, XHTML и XML.
Полная поддержка Unicode (UnicodeString или WideString в зависимости от версии Delphi).
Чтение и запись более 70 наборов символов (не зависит от ОС). Более 150 поддерживаются с помощью DIConverters.
ENG
DIHtmlParser is a fully Unicode aware HTML parser for Borland Delphi. DIHtmlParser gives you the power and flexibility to process HTML documents fast. It fully supports Unicode / WideStrings for both reading and writing and can convert all commonly used character sets natively, i.e. without the help of the operating system.
The core TDIHtmlParser component reports all types of HTML pieces plus a few HTML-related pieces to the application, which include HTML-Tags, text, comments, scripts, styles, titles, Custom-Tags, SSI, and more. All tags are parsed into a TDITag object which can be easily queried for attribute names and values. Filtering is available for all HTML pieces as well as individual tags.
The TDIHtmlParser component also accepts plugins, which the parser feeds with information durint the parsing. Any number of plugins can be assigned to a parser, and each TDIHtmlParserPlugin has the same processing and filtering options as TDIHtmlParser. Besides this, the plugins' and the parser's settings are completely independent of each other.
This plugin architecture allows to easily extend TDIHtmlParser. A number of ready-made plugins are included and cover frequent HTML tasks: extract e-mail addresses, links and titles, automatically write HTML, monitor character set changes, track HTML tables, implement HTML events, and more. Full source code is provided for all plugins as a starting point for writing new ones.
The HTMLParser reads HTML from memory or from any TStream object, using an internal buffer to speed up the reading. It automatically decodes entities and correctly handles preformatted text. "Smart parsing" skips unused HTML pieces and results in an amazingly fast parsing performance.
DIXml v2.2.0 Component For D7, XE Cracked + Demos
DIXml is an embedded XML, XSLT, and EXSLT processing library for Borland / CodeGear Delphi. It is build on the libxml2, libxslt and libexslt libraries. However, DIXml requires no DLLs or any other external files whatsoever. All required code is compiled completely into the application's executable. DIXml is the most feature-complete XML and XSLT solution for Delphi.
DevArt SDAC v6.1.3 for D7,XE,XE2
SQL Server Data Access Components - многофункциональный инструмент для разработки клиент/сервер приложений на Borland Delphi и C++Builder для Microsoft SQL Server. SDAC предоставляет гибкий и простой способ автоматического обновления данных на сервере, расширенные возможности по обновлению записей, получения метаданных, и многое другое.
Clever Suite Internet v7.4 D5-XE2 Full Source
The suite of the Clever Internet components presents the most efficient and convenient way of accessing the Internet resources from your applications.
Using the Clever Internet Suite (Clever Internet .NET Suite, Clever Internet ActiveX Suite) you can add instant SSL / TLS security to your Internet applications and implement many useful Internet-related features:
downloading, uploading and submitting of the Internet-resources; sending and receiving MIME messages; HTTP, FTP, SMTP, POP3, IMAP and NNTP client / server solutions; SSL / TLS channel with digital certificates support.
The suite includes more than 40 components for Internet development and its code is constantly being refined and improved.
Rubicon.v2.21 Full Source for D7
Rubicon is a set of Delphi components that performs full text search. Rubicon is compatible with all versions of Delphi and C++ Builder. This demo uses the Rubicon components to index and search a database table. The major elements of the demo consist of:
-Tables Tab
-Index Tab
-Build Tab
-Search Tab
-DBGrid Options
How Rubicon Works
Rubicon can process database records, text files, RTF files, HTML files, and other files that can be converted to text. Rubicon processes the text, identifies the unique words in the text, and then assigns a unique integer location to the words. For example, if a database table has 1000 records that are indexed on CustomerNo starting at number 1001 and ending at 2000, all the unique words contained in the record at index location 1001 would be identified and assigned an index number of zero (CustomerNo minus the lowest CustomerNo, or 1001 - 1001). This process is repeated for all the records. The result is a Words table which contains all the unique words in the table and a bitmap or index of there locations in the table. With these indexes, a search for "John Smith" simply requires reading and ANDing the bitmaps for the words "John" and "Smith".
Visual Controls
Rubicon includes two visual controls, TrbHints and TrbRichEdit. The TrbHints control is demonstrated in the Search Tab and is visible in the Hints sub tab. TrbRichEdit is a RichEdit control that performs matching word highlighting. This component may be seen in the 32 bit version of the demo when displaying a memo field in the Match table.
Dynamic Updating
Rubicon is not only capable of building and searching indexes, but it can also maintain them as changes are made to the Search table. To see this in the demo, build the indexes, then display the Search table (Ctrl+T) and turn off the Read Only property (Ctrl+R). Before making a change, you may wish to open the Words table (Ctrl+W) so you can see the table updated as the changes are made. Return to the Search table and make one or more changes. You will see the changes reflected in the Words table and when you return to the Search Tab, you will be able to search and find the changes.
SQL Tables
The demo will work with SQL tables. However, with large SQL tables, performance at times may be sluggish because Rubicon has to find the first and last records in the table. In a real application, the first and last index value are likely to be know (e.g. the first index value is 1000 and the last index value can be retrieved from a generator), and may be set in Rubicon events. Rubicon also includes drivers that perform all table access via TQuery components.
Блуждая просторами интернета вот наткнулся:
DevArt UniDAC v.4.1.4 (28-Dec-2011).rar
multiupload.com давно мертв.
Если кому надо вот рабочие ссылки (91.3 mb.)
DevArt UniDAC v.4.1.4 Full Source
Для всех версий Delphi и BCB6. Исходники присутствуют.
TinyDB v2.93 Full Sources (Delphi 2005 до XE2.)+Demo
TinyDB представляет собой небольшой, быстрый и очень надежный механизм базы данных для разработчиков.
В отличие от существующих решений для обработки данных в TinyOS, TinyDB не требуется писать код.
Вместо этого, TinyDB обеспечивает простой SQL-подобный интерфейс для указания данных, которые необходимо извлечь, а также дополнительные параметры, как скорость, с которой данные должны быть обновлены. При запросе необходимо указать ваши базы данных, TinyDB собирает данные с помощью специальных алгоритмов обработки.
Он обеспечивает доступ к БД в собственном формате без BDE, и не требует установки и настройки.
С компонентом TinyDB, все данные могут быть сохранены только в одном файле базы данных. TinyDB компонент является идеальной заменой BDE для небольших приложений БД.
Основная цель TinyDB, чтобы облегчить жизнь программисту при написании приложений управляемых БД, которые будут разработаны и развернуты быстрее, чем это возможно с традиционными компонентами. TinyDB освобождает вас от бремени написания низкоуровневого кода...
Ключевые особенности:
  • Унаследованные от TDataSet, поддерживает всеми визуальными DB-компонентами
  • Без BDE, DLL и OCX
  • Все данные в одном файле БД
  • Поддержка BLOB сжатие данных
  • Поддерживается шифрование БД, и формат CRC32 защиты
  • Поддержка In-Memory Database
  • Поддержка среды Multi-indexes, Master-Detail
  • Максимальное количество записей более 100.000
