Cindy components V5.11 (DBX components improvments)
Need access mySQL tables like you do with BDE tables or other local tables?
DB Express tables (TcyTable and TcySimpleTable) brings to you the better of 2 worlds:
- SQL
- Simple access/modification with automatic updates and refresh, record locks etc ...
Develop with TcyDbxSimpleTable like you did with BDE components!
Download demo zip files to see how it is easy and fast to develop with Cindy components!
DBX components changes since v5.10.2:
13/11/2012 - cyDbxTable.pas - Added RecordLockOptions: TcyDbxRecordLockOptions for cindy record lock feature
13/11/2012 - cyDbxSimpleTable.pas - Added RecordLockOptions: TcyDbxRecordLockOptions for cindy record lock feature
08/11/2012 - cyDbxBaseTable.pas - Created unit
08/11/2012 - cyDbxSimpleTable.pas - Added property Provider: TDatasetProvider to handle properties and events on object inspector
08/11/2012 - cyDbxSimpleTable.pas - Removed needless property ProviderOptions: TcyProviderOptions
08/11/2012 - cyDbxTable.pas - Added property UpdatesOptions.SendResetAutoIncCmd: Boolean
08/11/2012 - cyDbxSimpleTable.pas - Added property UpdatesOptions.SendResetAutoIncCmd: Boolean
Core changes since v5.10.2::
15/11/2012 - cyDBX.pas - Added function SQLReturnFieldValueAsString()
13/11/2012 - cyDBX.pas - Added function SQLGetPrimaryKey()
13/11/2012 - cyDBX.pas - Renamed SQLConnection_GetLastInsertID() to SQLExecute_GetLastInsertID()
13/11/2012 - cyDBX.pas - Created function BackQuotedStr()
12/11/2012 - cyDBX.pas - Added functions GetInternalRecordLockId() and IsFreeLockId()
08/11/2012 - cyDBX.pas - Added SQLExecuteInsert() function that retrieve PrimaryKey value of inserted record
08/11/2012 - cyDBX.pas - Added const OnlyFirstFound: Boolean parameter on function ExtractSQLTableNames()
I would like to thank all support messages (and donations of course).
Because Cindy components are used by professional companies, you can use them with no worry.
Also, bugs are corrected in 24 hours after report!
Because it' s free, i would like to thank all donations made or will be done.
Mauricio
Cindy components developper
