FIB-ы не битые?
На ru-board-e жаловались, что гуляет перевыкладка с чехов, где FIBPlusEditors не хочет ставиться на 2007-ю.
Добавлено через 1 минуту
Да, уже прочитал по поводу FibPlus
Missing source files of Editors and Tools
The source file of Editors and Tools are missing
The editors can be compiled from older versions source if replace the new Fibconst.pas with old versions of file
Да, и еще - тут вроде как выкладка Fibplus - OFFTOP
FIBPLUS 7.4.1731 XE2-XE3 Re-Pack with_Editors/Tools and CORRECTIONS
- I did some changes for to install in XE2 --> NOW with Editors and Tools menus.
- in "Options" definitions: Conditional defines, Output Directory, Output C++, Description, Version info, etc...
- in regfibplusutils.pas some corrections for XE2, as:
--> type PCHAR --> PWideCHAR
--> type integer --> Cardinal
--> D9+ --> D2009+
ToolAPI class "TDebuggerNotifier= class(TComponent, IOTADebuggerNotifier)" dont compiling without this changes
procedure TDebuggerNotifier.ProcessCreated({$IFDEF D9+}const {$ENDIF}Process: IOTAProcess); --> procedure TDebuggerNotifier.ProcessCreated({$IFDEF D2009+}const {$ENDIF}Process: IOTAProcess);
NOTE: "D9+" was defined, so, right will be "D2009+"
Some functions needs type Cardinal and not allow type Integer
VerQueryValue(Buf, constVerFileDescription, pointer(Value), Len) ---> VerQueryValue(Buf, constVerFileDescription, pointer(Value), Cardinal(Len))
GetFileVersionInfoSize(PChar(S), n) ---> GetFileVersionInfoSize(PWideChar(S), Cardinal(n))
Important! In various part of the files, the programmer use "definitions" not definided in files INC, as:
-- D9+, will D2009+
-- D4+, not definided
This, can be the cause for many error during the compiling. Delphi XE? use diferente types in diferente cases (32bit / 64bit).
Always verify the definitions in the files for your system!
In geral, its all! For XE2 v16.0.4504.48759, the compiling and install occured with not problem (FIBPlus/Editors/Tools)!
Note: Sometimes, can occur that the Delphi say: "UNABLE to install the component". Just close the IDE, and run again!
:beer:
NO MIRROR PLEASE
Wireless Communication Library 6.11.0.0
Приветствую, господа!
Вышла новой версии Wireless Communication Library 6.11.0.0.
Что нового
  • Kinect support in WCL Developer Commercial;
  • Icons for wclGSMModemClient (.NET and VCL Editions) have been added;
  • WCL C++ and WCL .NET Editions: bug with using default constructors has been fixed;
  • WidComm BT 2.1 pairing issue has been fixed;
  • PairEx method has been removed from wclAuthenticator class;
  • Pair checks if wclAuthenticator is active and fails in this case;
  • Code refactoring and optimization;
  • OnAuthenticationRequest event has been removed from wclAuthenticator;
  • New events have been added for wclAuthenticator: OnNumericComparison, OnPasskey, OnPasskeyNotification;
  • Pair method has been changed to work as PairEx;
  • New events OnPINRequest, OnNumericComparison, OnPasskey, OnPasskeyNotification have been added to wclBluetoothDeviceClass;
  • Demos have been updated and modified to support new features;
  • Fixed bug when OnPaired event doesn't fire when wclAuthenticator is used with WidComm Bluetooth drivers;
  • Fixed bug when application uses more than one instance of wclAuthenticator to handle authentication (paring) requests from more than one installed radio.
Остальное, как обычно:
1. Только для некоммерческого использования. Подразумевается использование без извлечения прибыли: фривара, для себя любимого и т. п.
2. Коммерческая лицензия доступна с большими скидками. Обращайтесь на Как увидеть ссылки? | How to see hidden links?, будем рады.
3. Как получить. Стучите нам на Как увидеть ссылки? | How to see hidden links?
Если от нас долго (более 3-х часов) нет ответа, то либо у нас ночь и я сплю либо ваше или наше письмо было уничтожено спам-фильтром. По сему можно кинуть в нас еще раз на Как увидеть ссылки? | How to see hidden links?
Внимание: даже если получаете Developer Commercial - она НЕ МОЖЕТ быть использована в коммерческих целях.
Ну вот как-то так.
У нас тут с системой обновлений был косячокс по сему автоматом не открылся доступ к последней версии. Сейчас поправили ручками, можете заходить в свои аккаунты и смотреть 6.11.0.0. Приношу извинения за проблему.
Хотел бы уточнить:
1. Правильно ли я понимаю - обратившись на мейл можно получить библиотеку бесплатно для некоммерческого использования ?
2. Исходя из п.1, эта версия (полученная по мейлу) полнофункциональная или существуют какие-то ограничения ?
Приветствую!
Лучше не засорять тему, как мне кажется, а писать нам :) Тем более, что здесь я появляюсь не часто и могу просто не увидеть вопроса.
По теме:
1. Да, совершенно верно.
2. Полнофункциональная. Никаких ограничений в коде там нет. Кроме нашей просьбы здесь не использовать в коммерческих проектах и не распространять :)
Cindy v5.12 Xmas edition released!
- Added TcyPageControl and TcyTabControl components.
- Minor bugs corrected
Please make donation if you use Cindy components on your projects: i need new computer.
есть последний TMS Component Pack ? больше всего щас инетересует
TAdvListEditor из набора
или может в каких нить других компонентах есть что нибудь подобное
* BusinessSkinForm VCL v10.10 (24 November, 2012)
* DynamicSkinForm VCL v12.80 (24 November, 2012)
My favorites. Thank you SERGEYX.
TMSIntraweb please
TMS IntraWeb Component Studio
