FastCube VCL Professional v1.10.3 for Delphi & BCB Full Source
FastCube is a tool for effective data analysis.
FastCube enables to create various reports and diagrams instantly irrespective
of the database size.
FastCuhe is a handy tool for efficient analytical data arrays handling.
FastCube usage for report building does not require programmer's high skill level.
You can build FastCube into your applications created in Delphi or Lazarus
environments by way of components' set.
Connection to any datasource wich supports "TDataSet" interface.
There is an opportunity to build ready-made templates for the cube and to prohibit
user's scheme modification.
You can export cube's cutoff into Excel, Word and HTML.
All cube's settings may be performed both by program and a user.
Добавлено через 2 минуты
USBPhysic DLL Component v1.1.0 (x86/32-bit)
USBPhysic is a stand-alone component ( 32/64-bit Windows dynamic-link library - DLL ) that can be used to extract the physical vendor information from almost any USB (Universal Serial Bus) storage device. With USBPhysic you can get the manufacturer serial number, manufacturer name and so on, of the external portable Hard Drives, flash/pen/key drive or any other kind of USB Storage Device.
As you know some of the physical information, actually only the serial number, is a unique number/string per device and this offers you a chance to programmatically identify the actual device.
Let's say you want a way to lock your software to a USB storage device (a small flash pen), or distribute your software only with a USB stick, a fast and reliable way to do that is by generating a serial number based on that USB device serial (the hardware serial number that can not be changed, even after a full format). The physical serial number is not the same as the volume serial number, it will not change after a format, and there is no way to change it unless you change the actual device.
[features] Features:
USBPhysic is a stand-alone component, does not require any other files to work.
It uses the drivers on Win32/64 platforms so there are no special library/driver requirements.
It can be used in any programming/scripting language that can make WINAPI calls like: Delphi, C++Builder, C#, Visual C++, Visual Basic, Visual Basic.NET, VBA, PowerBuilder, Visual Foxpro, Clarion and so on.
Does not require administrator rights anymore on Win XP/2003/VISTA/7 (works even with a guestaccount type)
Добавлено через 4 минуты
Apollo 7 Embedded
Apollo Embedded includes everything developers need to create Windows, .NET and classic ASP applications that manage CA-Clipper and FoxPro 2.6 DBF/Xbase database files. Developers can create single and multi-user desktop and web-based database applications using Delphi, C++Builder, RAD Studio, Visual Studio (C#, VB.NET), classic Visual Basic, VBScript and C/C++ that run on Win32, .NET and classic ASP .
The Apollo embedded database engine features a small 1MB footprint that delivers high-performance, low-overhead data management. Apollo applications are smaller, more robust and easier to deploy than applications developed using Jet, MSDE or the BDE. Because of Apollo's small footprint and royalty free Copy 'n Go!™ deployment, applications can be distributed easily over the Internet with no concerns for download size, configuration or licensing.
Includes everything you need
DBF Support - CA-Clipper, FoxPro 2.6 files (DBF/NTX/DBT, DBF/CDX/FPT, DBF/NSX/SMT)
Components - ADO.NET Data Provider, VCL TDataSet and Win32 components
Database Engine - Embedded DBF/Xbase database engine with SQL support
Tools - dbfUtils Lite for visually managing DBF/Xbase files
Добавлено через 7 минут
DevExpress 12.1.7
DevExpress offers numerous subscriptions for your software development needs. Our best and most cost effective offering is the Universal Subscription - a comprehensive and feature complete software development toolset for .NET developers. It includes all DevExpress Controls, CodeRush and the award winning XAF business application framework in one integrated package. When only the best will do.
crack Как увидеть ссылки? | How to see hidden links?
Добавлено через 9 минут
MiTeC.System.Information.Component.Suite.v10.9.2.Full.Source
MiTeC System Information Component Suite consists of
many standalone components covering many system information problematics.
Here you can see hierarchy tree and screenshots of selected features.
PASS:
Добавлено через 14 минут
EMS Advanced Excel Report v1.9.1.1 Full Source
Advanced Excel Report for Delphi is a powerful band-oriented generator of template-based reports in MS Excel. Easy-to-use component property editors allow you to quickly create powerful reports in MS Excel. Now you can create reports, which can be edited, saved to file and viewed almost on any computer. Advanced Excel Report supports Delphi 5-7, 2005-2007, 2009, 2010, XE, XE2 and MS Office 97 SR-1, 2000-2010.
Key Features
Creating report templates directly in MS Excel
Saving template as in the external *.xls file, as in the *.dfm (.exe) file
Band-oriented report generator
Any data source can be used
Creation of master-detail reports and reports with grouping
Full integration with Delphi IDE
High productivity even on slow computers
Detailed help system and a demo application for a quicker mastering of the product
Powerful component and property editors, which allow you to set many report parameters at the design-time easily
Добавлено через 15 минут
TMS Cloud Pack 1.5.2.1 Full Source
Includes
TAdvDropBox: component for access to DropBox cloud storage
TAdvSkyDrive: component for access to Microsoft Skydrive cloud storage
TAdvGDrive: component for access to Google Drive cloud storage
TAdvTwitter: component for access to Twitter API service
TAdvFacebook: component for access to Facebook API service
TAdvGCalendar: component for access to Google Calendar API service
TAdvURLShortener: component for access to Google URL Shortener API service
TAdvLiveCalendar: component for access to Windows Live Calendar API service
TAdvLiveContacts: component for access to Windows Live Contacts API service
TAdvWeather: component for access to weather forecast service
TAdvWeatherLocationLookupProvider: component that can perform lookup based on the available locations the Wunderground weather service provides weather data for
TAdvCloudLookupEdit: edit control with lookup dropdown showing matches while typing
TAdvGoogleLookupProvider: component that can perform lookup on a partial string for the most frequently used Google search terms
TAdvGoogleLocationLookupProvider: component that can perform address lookup based on Google Maps address data
TAdvCloudImage: component to display images from an URL
Добавлено через 16 минут
TVideoGrabber 8.6.2.10 VB6, DotNet and for D5-DXE3 All in One Cracked
TVideoGrabber is a video capture / media player SDK for development of C#.NET, VB.NET, C++, Delphi, C++Builder, and ActiveX-compatible applications. Powerful and intuitive to use, TVideoGrabber will help you to save time, money and effort to include video and/or audio capabilities in your project.
TVideoGrabber captures and records video and audio streams from most of video capture devices like USB webcams, USB analog capture devices, MJPG or RTSP IP cameras, desktop, as well as from set of bitmaps used as video source.
It support most of the encoding formats, natively or by using third-party codecs.
TVideoGrabber is also an advanced media player that lets play audio/video clips at their normal speed, faster, slower, forward and backward, one by one or through a playlist.
It is possible to capture frames, overlay graphics and text during preview, recording or playback, perform PIP video from another TVideoGrabber component, apply video processing like rotation, cropping and more.
TVideoGrabber can merge several clips into a single one, split a clip into smaller clips and re-encode them to different formats.
TVideoGrabber includes a single component the following features:
TatukGIS Developer Kernel v10 1.0.9781 for D2007-DX2
The TatukGIS Developer Kernel (DK) is a comprehensive GIS component (SDK) for custom development of stand-alone, embedded, and client-server applications. The DK is known for performance, logical design, compliance with many open standards, and reasonable licensing. Features include an extensive object API, support for most database engines, native support for most data formats, advanced coordinate system support, networking, geocoding, 3D mapping, and much more. Product editions are available for multiple development platforms:
Embarcadero Delphi/C++Builder VCL
Microsoft .NET for WinForms
Microsoft ActiveX/OCX
Microsoft Compact Framework (for mobile solutions)
Each edition reflects the same or very similar framework, API, and technology. For example, the source code of a .NET WinForms application is exactly the same as a Compact Framework application. This means that porting a GIS application between development environments, e.g., Visual Basic, VB.NET, Visual C++, C#, .NET, Compact Framework, Delphi, C++Builder, etc., is possible without great difficulty. (See comparative code example.)
For enterprise-level solutions, support is available for advanced spatial databases: Oracle Spatial & GeoRaster, Microsoft Spatial, ESRI ArcSDE, IBM DB2 Spatial Extender, IBM Informix Spatial DataBlade, MapInfo SpatialWare, and PostGIS.
The DK component is licensed per registered developer and is free of deployment royalties in most situations. The product is used by solution developers in over 50 countries and a wide
Synopse PDF Engine v1.18 Delphi 5-XE3
SynPdf unit can now link to standard ZLib.pas unit if you want to use it stand-alone and do not need our faster SynZip.pas + deflate.obj + trees.obj.
Добавлено через 1 минуту
AlphaControls v8.10 Full Source D5-XE3 Stable
28.11.2012 AlphaControls v8.10 Stable released
* Added SysSubMenu property in the TsSkinProvider component
* Added new aligning type (taCenterInSpace) for title items in TsTitleBar
* Improvements in the TWebBrowser support
* Small bugfixes and improvements
Devart UniDAC v.4.6.11 D5-XE3 Full Source
4.6.11 17-Dec-2012
Rad Studio XE3 Update 1 is now required
C++Builder 64-bit for Windows is supported
Bug with getting default values for fields with aliases is fixed
Bug with storing Specific options is fixed
Bug with using quoted field names in the IndexFieldNames property is fixed
Bug with processing macros named in Cyrillic is fixed
Bug in TUniStoredProc with closing dataset when the Disconnected property is True is fixed
RxLibrary 2.75 1.010 for Delphi 2005-XE3
Intraweb v12.2.12.1 for Delphi XE2
Envision Image Library V2.58 FullSource for CB6,D7-DX3
EMS Advanced Query Builder v3.9.1.1 Full Source
QuickReport v5.05 Pro for XE,XE2,XE3 (32/64)
Remobjects DataAbstract VCL v7.0.65.1067 Retail
TMS WebGMaps v1.5.0.1 Full Source
Firemonkey Premium Style for RAD Studio XE3
BusinessSkinForm VCL v10.10
DynamicSkinForm VCL v12.80
LMD 2012 Complete Full Source for Delphi 6-XE2 / C++ Builder 6-XE2 -> 32/64 bit
Zipforge 6.10 Delphi 2009 - XE3 32 Bit Cracked
Magic CDDVD Burner Pro VCL 1.21 full source ported XE3
PNG Component Plus v1.00
Cindy components v5.14 for Delphi 7 to Delphi XE3
Packages with more than 60 components to build windows applications:
Gradient controls (labels, buttons, panels, TabControls) with features like colored bevels, wallpaper, shadowText, caption orientation etc...
TcyCommunicate and TcyCommRoomConnector allows communication between applications running in same computer session.
TcySearchFiles and TcyCopyfiles allow respectively search and copy files with pause/resume/abort features.
TcyResizer allow move and resize components at run-time like delphi 2009 does.
Advanced DBX components for easy table data handling (tcyDbxTable or TcyDbxSimpleTable), schema modifications (TcyDbxUpdateSql), reconcile handling (TcyDBXReconcileError) and table creation (cyDbxImportDataset1).
TcyMathParser can parse matematical expressions.
TcyWebBrowser allows view/edit html documents.
TcyDbAdvGrid is a DBGrid with advanced feature rendering like gradient fixed cells, multiselection handling, embedded graphic and memo fields etc ...
Wireless Communication Library 6.11.3.0
Приветствую, господа!
Вышла новой версии Wireless Communication Library 6.11.3.0.
Что нового
  • Bluetooth devices monitoring;
  • BluetoothDiscoveryDemo has been updated to show how to use Bluetooth Monitoring functions;
  • Fixed bug with freezing on MS driver when pairing;
  • wclBluetoothDevice. Pair method has been reworked: now it takes PIN as a parameter and does not fire events (all events have been removed from wclBluetoothDevice class). The Pair method trys to pair with device with given PIN. If a target device supports BT 2.1 SSP authentication, the Pair method automatically accepts numeric/passkey comparison. If a target device requires legacy PIN authentication then the Pair method trys to pair with given PIN;
  • BlueSoleil freezinbg on Pair function issue has been fixed;
  • WidComm pairing has been updated and fixed.
Остальное, как обычно:
1. Только для некоммерческого использования. Подразумевается использование без извлечения прибыли: фривара, для себя любимого и т. п.
2. Коммерческая лицензия доступна с большими скидками. Обращайтесь на Как увидеть ссылки? | How to see hidden links?, будем рады.
3. Как получить. Стучите нам на Как увидеть ссылки? | How to see hidden links?
Если от нас долго (более 3-х часов) нет ответа, то либо у нас ночь и я сплю либо ваше или наше письмо было уничтожено спам-фильтром. По сему можно кинуть в нас еще раз на Как увидеть ссылки? | How to see hidden links?
Ну вот как-то так.
P.S. Кто уже к нам обращался и не получил обновления, стукните еще раз.
Реакции: ZsA
RDPrint - definitive solution for all models MATRIX printers
For d2007/d2006/d6 only not full source
RDprint is the definitive solution in the preparation of reports for printing professionals quickly and accurately on all models MATRIX printers, Inkjet and Laser.
The component RDprint has features for printing characters with font size and style varied accents, character printing graphics and semi-ASCII commands, printing aligned values​​; possesses resources and Setup Preview, and besides printing allows your reports saved in files for later viewing or printing.
Ideal for printing, quickly, efficiently and with ease, Invoice, Invoices, Checks and all kinds of reports.
If you've programmed in MS-DOS (COBOL, Clipper etc.) will certainly find the RDprint simply FANTASTIC and will have no problem using it, and if you are starting now, do not worry because we offer several examples with sources that will facilitate its use.
Bass24 +Sample Demos + bass.PAS and addons x32/x64
BASS is an audio library for use in software on several platforms. Its purpose is to provide developers with powerful and efficient sample, stream (MP3, MP2, MP1, OGG, WAV, AIFF, custom generated, and more via OS codecs and add-ons), MOD music (XM, IT, S3M, MOD, MTM, UMX), MO3 music (MP3/OGG compressed MODs), and recording functions. All in a compact DLL that won't bloat your distribution.
LMD 2013.2 Complete FS - Delphi 6-XE3 / C++ Builder 6-XE3 - 32 / 64 bit
Incl. Demo + Help files
LMD VCL Complete 2013.2 (5 feb. 2013)
Contains LMD-Tools, IDE-Tools and LMD ElPack 2013
Delphi XE3 release contains 32bit + 64bit support.
More than 685 native components for any kind of task.
Full sourcecode of all controls included
All features of the most current platform release: LMD-Tools, ElPack and LMD IDE-Tools.
Extensive demo projects with sourcecode
