Fastreport VCL v4.13 Enterprise (Full Source)
FastReport® VCL is an add-on component that allows your application to generate reports quickly and efficiently. FastReport® provides all the tools necessary for developing reports, including a visual report designer, a reporting core, and a preview window. It can be used in Embarcadero (ex Borland and CodeGear) Delphi 4-XE3 and C++Builder 6-XE3.
Changes
+ Added Lazarus Beta support starts from Fast Report Professionnal edition. Current version allows preview, print and design report template under Windows and Linux platform (qt).
+ Added Embarcadero RAD Studio XE3 support
- fixed compatibility with Fast Report FMX installed in the same IDE. This version can co exist with Fast Report FMX version at the same time.
+ published "Quality" property of TfrxPDFExport object
+ published "UseMAPI" property of TfrxExportMail object
+ published "PictureType" property to ODF export
- fixed bug with expressions in RichEdit
- fixed bug in multi-column reports
- fixed exception in the report designer
- fixed bug with URLs in Open Document Text and Open Document Spreadsheet exports
- fixed format string in XLS OLE export
- fixed format string in XLS BIFF8 export
- fixed output of the check boxes on the highlighted lines in PDF export
- fixed bug with PDF anchors
- fixed bug when using two or more macroses in memo
