IntraWeb 12.1.25 for XE and XE2
setup + crack
FastCode.Libraries-0.6.4.zip
********** FastCode Libraries **********
.. What is does ..
The following library will replace the current RTL
code used by your application(s) with faster and
optimized for the latest processors.
Currently the following functions are supported:
RTL:
AnsiStringReplaceUnit
CompareMemUnit
CompareStrUnit
CompareTextUnit
FillCharUnit
LowerCaseUnit
PosExUnit
PosUnit
StrCompUnit
StrCopyUnit
StrICompUnit
StrLenUnit
StrToInt32Unit
UpperCaseUnit
Non - RTL Functions:
CharPos,
GCD,
MaxInt,
PosIEx
(and more to come ...)
.. Usage ..
To use it must include the "Fastcode" unit in the first order
of your uses clauses of your delphi project. If you're using
and alternative memory manager and/or FastMove the order should
be like:
FastMM4,
FastCode,
FastMove,
... etc ...
You may also take a look at "FastCode.inc" for custom modifications.
Charalabos Michael <chmichael@creationpower.com>
.. Donations ..
If you like my work on the libraries you can also donate.
Charalabos Michael Paypal Link:
Fastcode Project Paypal Link:
Thank you
Добавлено через 1 минуту
TPerlRegEx is a Delphi VCL wrapper around the open source PCRE library, which implements Perl-Compatible Regular Expressions.
This version of TPerlRegEx is compatible with the TPerlRegEx class in the RegularExpressionsCore unit in Delphi XE. In fact, the unit in Delphi XE is derived from the version of TPerlRegEx that you are using now.
The supplied pcrelib.dll contains PCRE 7.9, compiled with Unicode support. The supplied OBJ files contain PCRE 7.9, compiled with Unicode support. By default, the OBJ files are used. You can use the DLL if you have multiple applications using TPerlRegEx and you don't want to waste space by linking the OBJ files to be linked into each of those applications.
For more information about PCRE, please visit Как увидеть ссылки? | How to see hidden links?
For more information about regular expressions in general, please visit Как увидеть ссылки? | How to see hidden links?
You can download the latest version of TPerlRegEx at Как увидеть ссылки? | How to see hidden links?
TPerlRegEx is licensed under the Mozilla Public License, version 1.1.
This new version of TPerlRegEx descends from TObject. There are no packages to install into Delphi and nothing appears on the component palette. Simply add PerlRegEx to the uses clause of any units you want to use it in. There's no need to add the pcre unit to the uses clause. This unit is used internally by TPerlRegEx.
Добавлено через 5 минут
Components from SMImport suite allows to import a data from external file formats:
1. MS Excel spreadsheet (directly without OLE/DDE)
2. text delimited file
3. text fixed width file
4. XML file
5. HTML file
6. MS Access database
7. MS Word document
8. Lotus 1-2-3 spreadsheet
9. QuattroPro spreadsheet
10. Paradox table (directly without BDE)
11. DBase table (directly without BDE)
12. any ADO connection
13. any Advantage database
14. any DBISAM table
15. some dataset component
The wizard component from suite (like wizard in MS Office) allows to define a settings of import process visually.
Most components allow to load data from streams (memory, blobs, cgi etc)
To add the import component is simple way to expand the own application. Give a nice feature with ultimate performance for your end-users.
SMImport is a native VCL engine with multilanguage support.
SMImport suite is distributed as shareware.
This is not freeware or public domain.
You may use the shareware trial version for 30 days.
If after 30 days you would like to continue using it,
then you should purchase a license.
Benefits:
Minor upgrades and bug fixes are free to registered users.
Registered users are informed of upgrades and new software releases.
Registered users may supply the components royalty-free in their source code.
License fee is:
$50 for SMImport full suite (with sources)
$35 for SMImport lite suite (without sources)
You can download a latest version of product at:
You can order a product at:
Direct online registration:
1. Как увидеть ссылки? | How to see hidden links?
or
2. Как увидеть ссылки? | How to see hidden links?
Thank you for using SMImport suite.
SMImport.Component.Suite.v2.27.zip
4. XML file
5. HTML file
7. MS Word document
Benefits:
License fee is:
or
nrCommLib 9.27 Full Source for Delphi 3-XE2 + Demo
The nrComm Lib is set of Delphi VCL components, classes and routines for serial communication tasks. Library helps to get access to various devices: serial port, data and voice modems, barcode scanners, Human Interface Devices (HID), Bluetooth, USB, LPT, GSM, GPS and others. It provides solution for quick implementation almost any packet data protocol. It can work with sound and speech. Library allows send SMS messages over connected mobile phone (GSM terminal) and much more.
TMS Scripter Pro Ver from 12/21/2010 FS and Compiled Libraries for XE2 32 Bit VCL
This is obviously not the latest version of TMS Scripter Pro but it works with XE2 and comes with the XE2 Imports
TXLSFile library v.4.0. and XLSExport components Full source (edited to XE2)
TXLSFile is a Delphi library for reading and writing MS Excel XLS files. It is based on direct reading and writing of files, and works without OLE Automation with Microsoft Excel.
TXLSFile is distributed with XLSExport components package. XLSExport is a Delphi components package for quick data export into MS Excel file with one line of code.
IPWorks v8 Delphi Edition 8.1.4415 Full Sources - Up to Delphi XE2 (32 & 64 bits)
TeeChart Pro Version 8.0x Full Source and Compiled Libraries for XE2 32Bit VCL
This is obviously not the latest version of TeeChart Pro but it comes with full source so you don't need to find a crack when ever a new update of XE2 becomes available, you can just recompile the source code as needed
Before installing these libraries you need to remove the TeeChart Standard VCL Components that came with XE2 otherwise XE2 will try to use the dcu files it came with instead of the ones in this library
-Components > Install Packages > Remove TeeChart Standard VCL Components
-Next You will need to add the source directories of both TeeChart and TeeTree to your Library Path
-Now you can install the libraries
-Components > Install Packages > Install
-DclTeePro8XE2.bpl "located in the TeeChart Source Directory"
-DclTree2DXE2Tee8.bpl "located in the TeeTree Source Directory"
AutomatedDocking Lib by AutomatedQA Full Source and Compiled Libraries for XE2 32Bit
This is the best docking library I have ever used, unfortunately AutomatedQA no longer sells it, however I converted it to XE2 and will continue to use it because I haven't found anything that comes close to it.
You will need to add the source directory of AutomatedDocking Library by AutomatedQA ----Corp to your Library Path
-dclaqDockingManagerDXE2.bpl "located in the Source Directory"
Raize Components 6.0 - Full Source Code
Raize Components is a user interface design system for Delphi and C++Builder. At its center is a collection of more than 125 general-purpose native VCL controls. Built on a foundation of technology first created more than fifteen years ago, these high-quality components give developers unsurpassed power and flexibility without sacrificing ease-of-use. In addition to the core set of controls, Raize Components includes more than 100 component designers focused on simplifying user interface development. Now more than ever, developers use Raize Components to build sophisticated user interfaces in less time with less effort.
The primary focus of Raize Components 6 is on the new VCL capabilities that have been added to Embarcadero RAD Studio XE2. Specifically, 64-bit VCL support and the really cool new VCL Styles support. Unlike other releases of RAD Studio which simply required recompiling the existing code base to provide a new set of DCUs and packages, there were a lot of low-level changes made to the VCL in XE2. For example, many controls migrated smoothly to 64-bit, but many others required low-level modifications. In addition, every control in Raize Components was affected by the new VCL Styles. Each control's display code needed to be significantly modified to fully support for VCL Styles when they are available. It has been a lot of work, but we are certain that you will find the end result really cool!
There are other enhancements and fixes included in Raize Components 6, but 64-bit and VCL Styles support are the major new features. Raize Components 6 definitely leverages RAD Studio XE2, and to get the most out of RC6, you need XE2.
For a more detailed look at what's new Raize Components 6, please read the following PDF document:
What's New in Raize Components 6 PDF Document: RC6WhatsNew.pdf
So, don't delay, upgrade to Raize Components 6 today!
перевод Сократ:
Компоненты Raize является интерфейсом пользавателя проектой системы для Delphi и C++Builder. В своем центре - сбор более, чем 125 общего назначения исконных элементов управления VCL. Построенное в основании технологии сначала создавшей более, чем пятнадцать лет тому назад, эти высококачественные компоненты дают непревзойденную мощность и гибкость разработчиков не жертвуя удобство--использования. Дополнительно к сердцевине установленной элементов управления, Компоненты Raize включает более, чем 100 компонентных разработчиков сфокусированных на упрощающий интерфейс пользавателя разработки. Теперь более, чем когда-либо, разработчики используют Компоненты Raize, чтобы строить умные интерфейсы пользавателя в менее времени с менее усилием.
Первичный центр Компонентов Raize 6 находится в новых возможностях VCL, которые добавлены к Embarcadero RAD Studio XE2. Особо, поддержка 64- бита VCL и действительно холодная новая поддержка Стилей VCL. В отличие от других выпусков Студии RAD, которая просто требовала перекомпилируя существующую кодовую базу, чтобы обеспечивать новый набор DCUs и пакетов, были много изменений низкого уровня сделанных на VCL в XE2. Например, много элементов управления мигрировали гладко на 64- бит, но много другие необходимые модификации низкого уровня. Кроме того, каждое управление в Компонентах Raize было поражено новыми Стилями VCL. Каждый управляющий дисплейный код должен значительно быть модифицирован, чтобы полностью поддерживаться для Стилей VCL когда они доступны. Это было много работы, но мы уверены, что Вы найдете конечное действительно охлаждать результата!
Есть другие расширения и исправления включались в Компоненты Raize 6, но 64- бит и поддержка Стилей VCL является основными новыми характеристиками. Компоненты Raize 6 определенно использует в качестве рычага RAD Studio XE2, и, чтобы получать наиболее из RC6, Вам нужно XE2.
Для более подробного взгляда в котором - новые Компоненты Raize 6, пожалуйста прочитайте следующее документа PDF:
Что Новое в Компонентах Raize Документа 6 PDF: RC6WhatsNew.pdf
Так, не задерживайте, модернизируйтесь в Компоненты Raize 6 сегодня!
DevArt UniDAC v.4.1.5 (02-Mar-2012)
for Delphi 6 - XE2, BCB6
Universal Data Access Components (UniDAC) - библиотека компонентов для Delphi, Delphi for .NET, C++Builder и Lazarus (Free Pascal) для прямого подключения к базам данных Oracle, Microsoft SQL Server, MySQL, InterBase, Firebird, PostgreSQL, SQLite, DB2, Microsoft Access, Sybase Advantage Database Server, Sybase Adaptive Server Enterprise и др. (с использованием ODBC провайдера).
INFO:
-Update 4 for RAD Studio XE2, Delphi XE2, and C++Builder XE2 is now required
-Bug with Null values filtering in CRDBGrid is fixed
-Bug with the absent CRControls10p.res file in the installation for Delphi 2006 is fixed
-Bug with Data Editor in the design-time for case-sensetive Master-Detail link is fixed
-Bug with hanging RAD Studio XE2 when opening ConnectDialog is fixed
-Bug with AV failure at executing ApplyUpdates is fixed
-Bug at working with 64-bit pointers is fixed.
-Several bugs in design-time editors are fixed
Oracle data provider
-Code improvements for avoiding compilation warnings
-Support of case sensitive objects and their methods is improved
-Bug with DisconnectedMode=True and LocalFailover=True in the Direct mode is fixed
-Bug with representation VarArray data types when ObjectView=True is fixed
-Bug with showing INFINITY in TOraNumber fields is fixed
-Bug with loading Unicode strings by TUniLoader is fixed
SQL Server data provider
-Bug with getting IndexColumns metadata for SQL Server Compact Edition is -fixed
-Bug with the query that is generated for the QueryRecCount option is fixed
MySQL data provider
-Bug with processing a query with quoted column names is fixed
InterBase & Firebird data provider
-Bug with cutting a string when getting metadata from system tables in -Unicode mode is fixed
PostgreSQL data provider
-The Time(x) and the TimeStamp(x) data types support is improved
-Bug with showing error messages with German locale in Delphi 7 is fixed
-Bug with Out of memory in the server inside a Transaction is fixed
-Bug with sending parameters as Float value is fixed
-Big with schema names that contain "." is fixed
SQLite data provider
-Bug with using parameters whose names match to reserved words is fixed
ODBC data provider
-Bug with inserting, updateing and deleting data in SQLBase is fixed
How Does UniDAC Work?
UniDAC consists of two constituents. The first constituent is the general UniDAC Engine that provides unified programming interface for developers. The second constituent is the data access layer which consists of data access providers. These providers are intended for interacting between UniDAC Engine and database servers. Each data provider works with one specific database server. The general UniDAC structure is presented below:
TMS IntraWeb Planner 2.6.0.0 (TTIWWEBPLANNER – TTIWDBWEBPLANNER) for D5-XE2
Jazmine Calendar Widgets v3.50 Full Source
Незаменимый компонент для создания планировщиков, "напоминальщиков", личных дневников, записных книжек и всего, что связано с датами и временем.
В паке лежит три архива:
1. *.7z для Delphi 7-2005 проверенный мной (писал пару софтин на D7 с его использованием).
2. Пакет с поддержкой Delphi XE (в работе не проверял)
3. Архив с демо-примерами
Пакет устарел, но более свежей версии, к сожалению, нет в природе.
Платный? Вот, черт :(... Сейчас исправим...
madExcept 3.0 Full Source
-madBasic
!!! -madCodeHook
-madDisAsm
-madKernel
-madRemote
-madSecurity
-madShell
pass: delphi-z.ru
Может кто-нибудь поделиться компонентами для работы с USB (определение серийного номера, производителя, отлавливание подключения/отключения и т.д.)?
Еще есть маленький компонентик, но только для D7 и D2010. А может и к другим подойдет, я не знаю...
USB Component for Delphi7 and Delphi2010
Коллеги поделитесь пожалуйста Absolute Database 6.20
Выкладывали уже. Но только для XE2
у кого есть ZylGPSReceiver 3.63
Есть пак Zylsoft, но судя по файлу Справки (если эта справка не устарела, хз) ZylGPSReceiver в него входит версии 3.62. Других нету.
