ARReports Excel & Word cracked no source for Delphi XE2
ARExcelReport component designed to provide easy way for reports generation in Microsoft Excel. It is comfortable for use and may be used as a main or complementary reporting tool in your projects. Thanks to the original ideas ARExcelReport is fast enough and gives software developers and users rich abilities to create report easy in transportable format.
Highlights:
- Database-independent.
- Simple report templates creation direct in MS Excel using its full formatting abilities.
- Passing data into report by different ways including named text parameters, datasets and OnTag event.
- Data tables in report.
- Conditional blocks in report template.
- Custom SQL Queries in report template.
- Excel pivot tables in report.
- Direct dataset to XLS file convertion (no MS Excel required).
- Charts based on constant data area in report.
- Custom macros and interactive elements in report.
Compatibility:
- All of Excel versions.
ARWordReport component designed to provide easy way for reports generation in Microsoft® Word. It is very comfortable for use and may be used as a main or complementary reporting tool in your projects. ARWordReport gives software developers and users ability to create reports easy in transportable format.
Highlights:
-Database-independent.
-Simple report templates creation direct in MS Word using its full formatting abilities.
-Passing data into report by different ways including named text parameters, datasets and OnTag event.
-Data tables in report.
-Conditional blocks in report template.
-Custom SQL Queries in report template.
-Custom macros in report.
Compatibility:
-All of Microsoft Word versions.
Версия неизвестна. Исходников нет. Только BPL и DCU
Highlights:
Compatibility:
Highlights:
Compatibility:
