DrWeb сообщает:
Object: "ro_6.0.57.993_d16_upd4\remobjects software\pascal script for delphi\bin\psunitimporter.exe"
Type: infected
Virus: Trojan.Popuper.37228
Не обращайте внимание - это стандартная работа антивируса, они
всегда чем-либо недовольны
Мой Avast молчит, как разведчик. :D
Clever Suite Internet 7.5 Full Source
Version 7.5 (March 20, 2012).
The Clever Internet Suite Version 7.5 represents the expansion of the previous version 7.4.
In the new version 7.5 we have added new features, fixed existing bugs and solved some problems. Starting from version 7.0 the server functionality has been totally replaced and improved. New properties and methods have been added. Some existing properties, methods and events have been renamed or deleted in order to achieve better usability and clear Clever Internet Suite structure.
New Features
•RAD Studio XE2 / Delphi XE2 and C++Builder XE2 support;
•TLS1.1 and TLS1.2 support was implemented;
•Full 64-bit support;
•Full IpV6 support was implemented;
•DnsQuery / DnsServer - AAAA records were added;
•Soap - Timestamp, Addressing and SOAP WSDL were implemented;
•Http - the ability to cancel request and reset the connection;
•Smtp - receiving an information about message size limit;
•Smtp - starting from now you can send messages with long text lines which are greater than BatchSize property;
•Encoder - displaying of progress information was improved.
anyone can help me to give recommendation for good speech recognizing component?
or if anyone have component that related to speech recognizing, speech to text trainable, can you send it to me?
thx in advance
Clever Suite Internet v7.5 Full Source+Demo+Help (for Delphi XE2)
Компоненты Clever Internet Suite позволяют рассылать и получать почту в различных форматах, включая текст, HTML и прикрепленные файлы из вашей программы, скачивать и загружать файлы и данные в сети интернет с помощью большинства известных интернет-протоколов.
В настоящее время Clever Internet Suite включает более сорока компонентов для работы с Интернет-протоколами.
Основные возможности:
* Поддержка FTP, HTTP, SMTP, POP, IMAP, NNTP, DNS, SSL, S/MIME и многих других протоколов;
* Набор серверных компонентов для следующих протоколов: FTP, POP3, SMTP и IMAP4;
* Простота создания и отправки почты любого формата. Создание и отправка полей веб-формы методом POST;
* Персональная тех. поддержка;
* Документация, демо программы для Delphi
Установка:
  1. Установить Демо
  2. Заменить файлы (в архиве есть доп. архив)
Версия 7.4 внутри
Добавлено через 15 минут
Установка:
И тут тоже 7.4 в исходниках. Хотя бы размер файлов сравнили или тупо дату с 7.4 перед тем как постить.
AlmDev SmartEffects v2.5 Full Source
SmartEffects is an easy-to-use VCL that enables you to create amazing splash screens, forms, controls and image transition effects.
Over 50 families of animation and transition effects. Real-time rendering. WYSIWYG editing of animation effects.
SmartEffects is intended for use with:
-Delphi 2009, 2010, XE, XE2
-C++Builder 2009, 2010, XE, XE2
-Delphi 2007
-Delphi 2006
-C++Builder 2007
-C++Builder 2006
-Turbo Delphi
-Turbo C++
-Delphi 2005
-Delphi 5,6,7
-C++ Builder 5,6
QuickPDFLibrary v8.14 + license key
Quick PDF Library is a powerful royalty-free PDF developer SDK used by thousands of developers for working with PDFs on all levels. Including a robust API with over 500 functions for use with C, C++, C#, Delphi, PHP, Visual Basic, VB.NET, ASP, PowerBASIC, Pascal and more, Quick PDF Library truly is the ultimate toolkit for project where you need to create, edit, secure, print, render, split, merge or manipulate PDF documents.
The library is available in ActiveX, DLL and Delphi editions. Single or multiple developer licenses can be purchased and a source code license is also available.
Key Features
-Create, render and print PDFs
-Secure, sign and protect PDFs
-Create, fill and edit PDF forms
-Split, merge, append and combine PDFs
-Extract text and images froms PDFs
-Edit PDFs initial view and document properties
-Add text, images and barcodes to PDFs
-Advanced support for JavaScript, bookmarks, vector graphics, GeoPDF
-Direct access functionality (load files from disk, not memory)
System Requirements
Desktop
-Windows XP (32-bit, 64-bit)
-Windows Vista (32-bit, 64-bit)
-Windows 7 (32-bit, 64-bit)
Server
-Windows Server 2003 (32-bit, 64-bit)
-Windows Server 2008 (32-bit, 64-bit)
