FastCube for Delphi XE3 (last new version 1.10.3)
FASTCUBE is a tool for effective data analysis.
FastCube enables you to analyze data and to build summary tables (data cutoffs) as well as to create various reports and graphs easily and instantly. It's a handy tool for efficient analytical data arrays handling.
No key for install just recompile. Use recompliler for integration with FastReport.
Share FastReport 4.13 for XE3 please.
kbmMemTable Pro v7.20.00 Full Source
We are happy to announce the immediate availability of kbmMemTable v 7.20.00.
- Added support for Delphi XE3.
- Dropped support for D7, D2005, D2006, D2007.
- SQL: Added support for conditional aggregates like: SELECT SUM(IF(fld5>5,1,0)) FROM table GROUP BY fld5
- SQL: Added Length(string) to standard functions.
- SQL: Added SQL support for LIMIT and OFFSET. Eg. SELECT * FROM table LIMIT 10 OFFSET 5
- SQL: Fixed bug with multiple AND/OR parts in statement.
- SQL: Fixed bug related to * (all fields) handling with aggregate functions.
- SQL: Fixed bug related to datatypes of source fields used by aggregate functions.
- SQL: Fixed bug when DELETE or UPDATE statement given without WHERE clause.
- SQL: Fixed bug: SELECT sum(fld4)+sum(fld5) FROM table GROUP BY fld3
- SQL: Fixed bug: SELECT count(*)+3 FROM table
- SQL: Fixed issues with HAVING
- SQL: Improved internal handling of field aliases and unique field names.
- SQL: Optimized performance on accessing source fields.
We have decided to drop support from v. 7.20.00 and on, for older than D2009 Delphi versions.
The main reason is because kbmMemTable starts to take advantage of features only available in D2009.
If you are using an older Delphi version, we are encouraging users to upgrade to a newer version supported by kbmMemTable.
Windows Shell Developer Tools
web site and examples : Как увидеть ссылки? | How to see hidden links?
Download :Как увидеть ссылки? | How to see hidden links?
Добавлено через 4 минуты
ZylGSM is a Delphi & C++Builder component that communicates with a GSM modem or phone with integrated modem (almost all new generation mobile phones).
Website : Как увидеть ссылки? | How to see hidden links?
Download : Как увидеть ссылки? | How to see hidden links?
This ZylGSM cracked ?
Spasiva SergeyX!!!
Great component.
Does anybody have the IEVision plugin for it? It is the perfect addition to the already useful ImageEn. I will really apprecciate if someboy can share IEVision.
Regards,
Pablo
[REQ] FastReport 4.13
Hi
Other changes:
- fixed compatibility with Fast Report FMX installed in the same IDE.
This version can co exist with Fast Report FMX version installed in IDE.
+ published "Quality" property of TfrxPDFExport object
+ published "UseMAPI" property of TfrxExportMail object
+ published "PictureType" property to ODF export
- fixed bug with expressions in RichEdit
- fixed bug in multi-column reports
- fixed exception in the report designer
- fixed bug with URLs in Open Document Text and Open Document
Spreadsheet exports
- fixed format string in XLS OLE export
- fixed format string in XLS BIFF8 export
- fixed output of the check boxes on the highlighted lines in PDF export
- fixed bug with PDF anchors
- fixed bug when using two or more macroses in memo
- other minor bug fixes
